    Results 1 to 3 of 3
      Tucson Arizona
      67 Camaro backspace
      Stock suspension with 69 disc brakes and hotchkiss small block springs and 327.
      Can I use 17x8 with 4 3/4 back space on the front?
      Joe
      "If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
      Then, you have enough horsepower."
      -Mark Donahue
      Tucson Arizona
      Any thoughts on this......I can get a great deal on two new wheels but wanted to know if I can use them first.
      -Mark Donahue
      Aug 2003
      Orlando, FL
      That is the perfect wheel. Use a 235/40 / 17 tire and your set. Plan on running .5 degree negative camber
