View Full Version : first gen hydroboost bracket
bobhamilton15090
01-30-2008, 07:28 PM
check out what nick has come up with. I have seen the second gen stuff and it turned out really nice. I convinced him to come to my house and measure out what is needed for the first gen. You can see the model he made here: http://www.camaros.net/forums/showthread.php?t=124412&highlight=hydroboost
if enough people want to get a bracket it will drive the cost down even more, so let me know what you all think
JSR69
01-31-2008, 08:03 AM
I'm not a member of Camaros.net or I would have post there. Tell him that I'm in for one. You can PM me with details and payment transaction.
As far as which version, I would want the flat version without the angle mill.
67 455 Bird ragtop
01-31-2008, 11:10 AM
Pretty sweet. Too bad I already sent my hydroboost to hydratech and had them mod it to fit my 1st gen 'Bird.
dipren443
02-01-2008, 06:50 AM
Steve,
Hey, I replied to your PM on camaros.net. Here are those dimensions I promised you. Take a look at these and tell me what you think. In my opinion, I would make the bracket for the clutch out of 1/8" plate (I have ATS' plate for the T56 on my firewall and it is 1/8 thick) and I can easily make the counter bore a little deeper and would probably do so for all of them. If you go another 1/4" on my counterbores, you will be left with an 1/8" of aluminum.
https://static1.pt-content.com/images/pt/2008/02/Thickness1JPG-1.jpg
dipren443
02-01-2008, 06:54 AM
https://static1.pt-content.com/images/pt/2008/02/Thickness2JPG-1.jpg
JSR69
02-01-2008, 07:05 AM
Nick
Leave the bracket as designed. I'll either install longer studs or use 1/2 nuts depending. PM with price and we'll make arrangements for shipping and payment.
dipren443
02-01-2008, 07:13 AM
Nick
Steve,
Sounds good. I will keep you posted. Nothing is concrete yet. When it is, I will let you know payment info.
Nick
bretcopsey
02-01-2008, 07:37 AM
Is the locating "nub" in the center bore at the 9 o'clock position something that could be changed? I am going to run a Cobra H-boost unit and I think it is clocked differently.
dipren443
02-01-2008, 07:41 AM
I don't see why not. Can you verify which way the unit is clocked and where the locating pin should be?
Nick
Taylor1969
02-02-2008, 06:37 AM
Nick,
I didn't realize that you are doing all of this work on the bracket.
I think that a 15 degree pitch the the others are talking about would really help. I can get you pics of my entire setup.
The bracket that you sent me seems to almost make the hydroboost point down. It makes the proportioning valve and lines of a stock setup interfere with the inner fender.
I will get you pics of everything today including how I made the system work with the stock clevis.
