View Full Version : Bending Leafs for Ride Height
Ranaexcavating
01-28-2008, 05:57 AM
Is it acceptable to heat and bend rear leaf spring to obtain the desired height?
wendell
01-28-2008, 08:19 AM
No. Send them to a spring shop and have then dearched.
astroracer
01-28-2008, 08:45 AM
Wendell is exactly right here... The REASON you don't want to do this is; Leaf springs are made from tempered steel (spring steel) and, as soon as you put a torch to them to "rebend" them, they will lose all of their temper and springiness in the area you have heated. This will lead to broken leafs in a very short time which will not be good... This is nothing to be done at home. Take W's advice and go to a spring shop to have then re-arched...
Mark
wendell
01-28-2008, 09:06 AM
Mark is more indulgent than I am. Hell, he's probably a better person than I am.
Ranaexcavating
01-28-2008, 09:27 AM
Mark
Thanks Mark
I'll check with a local "spring guy" today
Joe
Jim Nilsen
02-02-2008, 01:48 AM
Springs are reached or dearched with a BFH and very solid steel table.
