View Full Version : 68 Firebird 428 Build up
Relax428
01-25-2008, 01:37 AM
Started working on my 68 Firebird today.
Started with a freash Stock Sub-frame, Global West Control Arms and Varishock Coil overs
NvrDun71
01-25-2008, 08:35 AM
How are you mounting the varishock coilovers to the stock subframe?
rohrt
01-25-2008, 11:02 AM
:naughty: That frame makes a nice center piece to your living room.:naughty:
Relax428
01-25-2008, 12:02 PM
It does look nice there doesn;t it.
These coil overs are designed for stock frames and mount through the stck shock location I will take more pictures.
NvrDun71
01-25-2008, 04:20 PM
Hmmm....Have always been told that they were not a direct bolt in?? Heard you had to modify the stock shock mount?
Relax428
01-25-2008, 04:23 PM
My shocks fell right into place so I think it would be the same for your nova.
68RS350
01-26-2008, 08:12 AM
This issue for the shock mounting is how the coil over mounts to a stock lower control arm. When you buy new aftermarket control arms you have to specify if you want stock shocks or coil overs.
68Formula
01-26-2008, 11:24 AM
My SpeedTech lowers are supposed to work with either. But I stayed with standard shocks and springs.
Relax428
01-26-2008, 11:35 AM
The bottom shock mounts were a little bit tight. I took a Dremal and grinded away a little bit of material and now they fit the global west arms perfectly.
