    Results 1 to 15 of 15
      California
      Base clear...or acrylic?
      The guy doing the bodywork on my chevelle was talking to me about pait options. I told him I just want black and red solid colors. He suggested acrylic paint instead of base clear. he was talking about price difference as well as over all appearance. Im far from this stage but I need to start making decisions soon because I will be in iraq when the bodywork gets done and the ar gets painted. I could relly use some advise here.
      Feb 2003
      St. Louis, Missouri
      Base/clear, the price difference shouldn't be much more.
      OC CA
      X2 for base/clear, but it's going to be a lot more!
      Mark
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      Sep 2007
      Elizabeth City NC
      base clear, it will last much longer as well. kinda low budget low quality stuff. If you want to go with a single stage at least go with a urethane type
      67 camaro
      Dayton, Ohio
      Base and clear coat is the best. The brand of paint and clear coat will lower the cost too. PPG paint is very high in cost. On my 1967 Camaro, RM Diamont for the base coat and the clear coat is Rubber-seal 2300 Clear.
      Jeff
      http://www.kodakgallery.com/67rscamaro
      Feb 2007
      USA, TN
      If your are going solid color, I vote for Acrylic Urethane. You can still clear if you want. You can also flow coat PPG Concept DCC with two coats of 25% color and 75% clear.
      Oswego il
      If you want a black car go highest quality single stage. This will give you the deepest black, the base/clear blacks will look hazy/cloudy in comparison.
      I'm not really a car painter but I have been painting aircraft for a wile now. But in my limited experience a single stage black will haze, because evey time you wash it, it scratches, and the scratches will haze out over time, and wax will only fix the problem for a short time. Someone please correct me if I'm wrong.
      Aug 2001
      Connecticut
      I'm a big fan of diamont (R/M) base/clear - my car was painted in 1995 and the paint is still really really good.
      http://www.rmpaint.com/en_UK/products/range/diamont.xml
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Huntington,wv
      The single stage paints can be color sanded and buffed allowing scratched or faded paint to be brought back to life. Personally I like the look of a single stage paint job that has been buffed to dull luster. However w/two and three stage paints and with the different paint techniques out there now, you can layer colors and clear coats creating some awsome paint jobs. Good base/clear pt jobs should out last the acrylics as far as shine and durability. The more product that is needed the more expensive the paint job.
      Phoenix,Arizona
      ive painted with both and i like bc/cc, but i do believe that single stage acrylics can give just as nice a finish if done right and can also be more durable as well.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Dec 2007
      norman ok
      diamont to me looks the best once finished out of dupont, ppg , and diamont. it has that "wet" look when its done
      Phoenix,Arizona
      I am getting ready to paint a buddies truck with diamont. We did the door jambs and I do have to say I really like the way it lays out. Really nice!
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      my instructor when i was in school a few years back wouldnt use anything but diamont on his high end projects. i like it i just like to spray dupont, chromabase/clear on most vehicles but on my dads bel air we are finishing up diamont;) all the way baby. hahha but seriously its good stuff, in comparison with others i like it....if youve ever seen a red car that looks almost like youve got a fountain running over it its so wet.
      85 grand national-t66, supporting mods
      99 xtreme s10-daily slammed on flat black 20s, tons of body mods
      02 337 editon gti "1 of 1500"-audi tt drive train factory, recaros, bbs, votex body package"270hp 310 ft lb"
      79 trans am- pro touring/track/dd project
      Aug 2001
      Connecticut
      yep, diamont is good stuff; I got 'best paint' at a show a few years ago, they couldn't believe it was 10 year old paint!
      2006 Corvette Z06
