View Full Version : Speed Tech caliper brackets
matty b
01-14-2008, 10:23 PM
Hey does anybody know if it is required to have drum spindles or just the drum hubs with the speed tech brackets? I have chevelle disc spindles and after coming across these brackets I think I wanna use them but Id rather not have to buy drum spindles although I could probably grab a set fairly cheap. Please lemme know thanks!!
SamHatco
01-15-2008, 05:14 AM
Yes you do. My car had factory front disc brakes and when I did my big brake upgrade I got 69 front drum hub and turned them down so the C4 z06 rotort would fit over the hub. I used the disk brake spindles that were on the car.
https://static1.pt-content.com/images/pt/2007/08/779358955-1.jpg
Sam
zman1969
01-15-2008, 05:47 AM
I'd go the drum spindle setup -that way you can pull the complete disc setup off and either sell or store them for later use just my .02c :doh:
matty b
01-15-2008, 03:57 PM
ok so the disc spindles are ok to use, I dont wanna buy extra spindles and selling the stuff probably wont pay for much, I dunno anyone who'd buy used brake parts... thanks though answered my question
LarryB
01-16-2008, 08:16 PM
http://www.speedtech-performance.com/pdf/C5__Disk_conversion_Instructions_for_C4_Rotor.pdf
bretcopsey
01-16-2008, 08:24 PM
The difference between the disc/drum spindles is shown in this picture from David Pozzi's website. The upper bolt boss is shorter on the disc spindle. Therefore a braket made for a drum spindle would need a spacer to use on a disc spindle.
https://static1.pt-content.com/images/pt/2008/01/69spinside-1.jpg
This picture from Speedtech's site illustrates the "height" of the upper bolt boss on the drum spindle-the recessed area on the back of the bracket.
SamHatco
01-17-2008, 05:15 AM
That is correct, however, speedtch provides the correct spacer for the upper boss. Everything bolted up perfectly.
Sam
