View Full Version : Mono leaf rear with Multi leafs
JMD68RSSS
01-04-2008, 09:54 AM
I am buying a 67 rear with mono perches to use in my 68 with multi leaf springs.
Can I bolt it right in? I have read it is a good idea to use the DSE kits, but is it absolutly needed?
nancejd
01-05-2008, 12:46 PM
I'm not sure if they bolt in, but here is some info I found on the perches courtesy of David Pozzi.
http://www.pozziracing.com/rear_suspension.htm#spring%20perch%20differences
danbob67
01-06-2008, 02:16 PM
you dont have to have it but it is a safety kinda kit they have aluminum spacers that keep the leafs from shifting around I see jacked up trucks all the time with just the leafs and blocks without any kind of spacers like the DSE kit supplies but to me it dont look safe. I just got one from DSE Im going from mono to multi as well.
JMD68RSSS
01-07-2008, 09:31 AM
Thanks for the replies. So the single leaf springs are wider than the multi? I did not know that.
pdq67
01-16-2008, 12:55 PM
No, mono's are 2.75" wide and thin on both ends and 2.25" wide and thick in the middle!
Whereas multi's are 2.5" wide and of the same thickness stacked leave's..
pdq67
