    Results 1 to 9 of 9
      20x10 1st gen offset
      will a 20x10 wheel for a Bmw with a 35+ offset work w/ fender lips rolled without wheel tubs on a 1st gen firebird? if so what tire? thanks!
      1967 Firebird 400 4 speed
      4 wheel c5zo6 brakes + hydroboost
      18"sterns wrapped in RE-11's
      Oct 2006
      Corona, CA
      That is a 6.875" backspace on a 10" wheel, you need somthing more along the lines of a 5.5-5.75" backspace, so you'll need a spacer.
      As far as tire, a 285/30/20 is a safe way to go.
      Aug 2003
      Orlando, FL
      Remember a Firebird has a "Wide track" 1" wider rear then a Camaro. Since we normally set up Firebirds with 6.5" backspace, you are a maybe within a 1/8",
      thanks so......since im looking for 20x10's on ebay under bmw wheels they are usually given in mm offsets what range should stay within? thanks guys
      May 2007
      Midwest City, Ok
      Quote Originally Posted by LONE*STAR
      1" = 25.4mm
      Aug 2003
      Orlando, FL
      Correct
      so a +25 to +30 mm offset would be good on 20x10" rim?
      Aug 2003
      Orlando, FL
      That should be very close. If you want to be completely safe you may want to measure you rear end axle flange to axle flange. Make sure nothing has been changed. It should be 61"
      Oct 2006
      Corona, CA
      Quote Originally Posted by ProdigyCustoms
      Totally overlooked that, I read first gen, and immediately thought camaro. Good catch... like Frank says, your damn close then, but like he said, confirm your overall length first.
