    Results 1 to 5 of 5
    Thread: Help!!
      Oct 2006
      McKinney, TX
      Help!!
      I think I made a pretty big mistake...so don't laugh, I seek advice.
      I went with LH and RH full length floor boards because the previous owner/builder put in horrible patches with tar and a little bit of weld. Couple that with the decay in the toe boards, it seemed to me a good idea to do that, rather than a full floor and new firewall.
      So, got the passenger side in perfect. SOMEHOW, I welded in the driver side about 1/8" to 1/4" higher than the passenger side. I'm assuming this is a no-go situation and I'll have to go and get another driver side panel and cut out the old one.
      Am I stuck with this only possibility? Is there anything else that I can do? If I leave it, will it be impossible to align and drive correctly (safely)?
      HELP!??????
      thanks
      -mcw
      Jackson Ms
      all you would have to do is put a shim between the body bushing and the frame. broblem solved.
      Chris V
      SOLD
      Oct 2006
      McKinney, TX
      I haven't really measured the finals yet...but its around 1/4 higher in the front and 1/8 higher in the back...
      That seems to me an awfully fat shim...is that safe?
      Jackson Ms
      Quote Originally Posted by absintheisfun
      what do you think a solid body bushing is? it is a solid shim about 1" think.
      Chris V
      SOLD
      Even if you had to cut it out I don't think I would scrap the entire piece. A shim or two should do the trick. Most these old cars have shims in them from the factory anyway so it won't hurt to throw a couple in there.
