    Results 1 to 7 of 7
      Dec 2007
      michigan
      68 camaro backspacing question
      I was wondering if anyone knew what backspacing I can use on a 68 camaro with everything stock. I am planning on running 17's... I was thinking 17x8 in the rear with 4.5 backspacing. I would like run wider, if possible, without mini tubing it.. I would like the tire to be kept inside the wheel well as I may plan on lowering the car in the future.
      thanks.
      Feb 2003
      Houston, TX
      17x9 with 5.5 backspacing is an easy fit. Run a 275 wide tire.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Aug 2003
      Orlando, FL
      Quote Originally Posted by Nine Ball
      Yeah, what he said!
      Dec 2007
      michigan
      Thanks, I was hoping to be able to run a bit wider.
      I can't wait to get this project started. I am glad I came across this forum. I can tell already its going to be a big help.
      thanks again.
      Oct 2007
      Hi sorry for being Nieve 275 X 50 40 or 30?
      thanks
      Dec 2007
      michigan
      I was assuming 40 series. that would give close to the same tire dia of the stock 195 75 14 that my camaro has on it now, within close to a tenth of inch.
      here is a good source for quickly figuring out your tire dia and section width. It sure beats using a calculator. lol
      You can compare your stock tire size to any given combination..
      http://www.discounttire.com/dtcs/infoTireMath.dos
      Quote Originally Posted by justasquid
      To be clear, they never came with radials. So the 195/75R14 is the closest radial size to stock bias-ply available.
      Regardless the 275/40R17 is the choice of many here since it is the closest to stock height.
