    Results 1 to 3 of 3
      Indianapolis, Indiana
      Need help with firewall install
      Installed new firewall in my 67' Firebird, but I need to double check something before full floor is installed. I need to know if the firewall mounts are level from front to back or if they are inclined. I took some pics to show you guys. These are from the center of the firewall looking at the passenger side mount.
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Rural Retreat,VA
      I think thats how mine when in on my 69 Camaro. It took me a week before I would weld it in. Just make sure you subframe holes are centered so if you have to adjust it, you will a have some room.
      Merritt Island,FL
      I am doing a 67 Camaro and my fire wall is the same way.
      After market parts!!
      These perches should be straight so they lay flat on the subframe mount.
      I built a jig to install these.It catches all of the factory bolt holes so everything will fit up when finished.
      Check out my web site.
