    Results 1 to 11 of 11
      Jan 2007
      SOCAL
      will 17in wheels fit over 14 inch -6piston wilwoods?
      I have been trying to figure out what 18s to get (cheaper the better), but perhaps i can find a set of 17 in wheels to fit over the brakes...has anyone put 17s over the 14 in. wilwood brake kit? Will 17s fit? if so, i can save lots of $.......please help..
      thanks
      D
      Jul 2007
      Wake Forest North Carolina
      You put 14in Wilwoods (6 Piston) ... Cheaper the better on rims ... is it a road-track thrasher your building?
      You can call most of the Rim manufactures and they'll generally tell you which 'lines/models' fit as they generally test fit or have leading edge customers that have the latest biggest brakes and have ordered with them. Since your on a budget they'll be able to comment on which of the lower cost models/lines will fit. My 13in Wilwood's have plenty of clearance with 17" Budniks.
      Yes, 17'' wheels can fit over a 14'' rotor with Wilwood 6 piston calipers. We had this exact setup on ''The Mitchell Brother's ZR-28'' Camaro using Torque Thrust 11's before we upgraded to Budniks. They sure fill up the wheel! Since we did upgrade, I have a mint set of TT
      Jan 2007
      SOCAL
      Jan 2007
      SOCAL
      A little heavy, but not too bad for a steel wheel. 25lbs I believe for a 17x9.
      Jul 2007
      Weatherford, TX
      FYI, I happen to have a 17x9 cragar D window in the shop for my current project, and unless they're made really different from the soft 8 they tip the bathroom scale at a shade under 40llbs.
      Doc
      My bad. Another person on a forum claimed he contacted Summit directly for those exact size and type wheels and they said the shipping weight listed was 40lbs, but actual wheel weight was 25lbs.
      Jul 2007
      Weatherford, TX
      That's a hell of a lot of packing then. Aero and Bassett both make black steel wheels that are around 25 lbs, but they are only available in 15 inch sizes. Wish I could find one comperable in a 17!
      Jan 2007
      SOCAL
      Found a great deal on torq lites...18X8s....would have liked to have gone wide in the rear but dont have the cash.....
      I am very excited, new brakes, Hotchkis suspension, and wheels and tires....the car will feel like it is brand new.. i am very excited..i will post pics from start to now...
      Aug 2003
      Orlando, FL
      The 17s will not clear the 14" anyway. You need a full 16" Inside Diameter on the inner wheel shell, and I do not know of any 17" wheel that is going to have that.
