View Full Version : will 17in wheels fit over 14 inch -6piston wilwoods?
s4dustin
12-17-2007, 07:34 AM
I have been trying to figure out what 18s to get (cheaper the better), but perhaps i can find a set of 17 in wheels to fit over the brakes...has anyone put 17s over the 14 in. wilwood brake kit? Will 17s fit? if so, i can save lots of $.......please help..
thanks
D
dharrod
12-17-2007, 07:45 AM
You put 14in Wilwoods (6 Piston) ... Cheaper the better on rims ... is it a road-track thrasher your building?
You can call most of the Rim manufactures and they'll generally tell you which 'lines/models' fit as they generally test fit or have leading edge customers that have the latest biggest brakes and have ordered with them. Since your on a budget they'll be able to comment on which of the lower cost models/lines will fit. My 13in Wilwood's have plenty of clearance with 17" Budniks.
perry mitchell
12-17-2007, 07:59 AM
Yes, 17'' wheels can fit over a 14'' rotor with Wilwood 6 piston calipers. We had this exact setup on ''The Mitchell Brother's ZR-28'' Camaro using Torque Thrust 11's before we upgraded to Budniks. They sure fill up the wheel! Since we did upgrade, I have a mint set of TT
s4dustin
12-17-2007, 08:54 AM
pics and price and size
s4dustin
12-17-2007, 11:00 AM
thoughts on Crager Soft 8 wheels?
68Formula
12-17-2007, 12:12 PM
A little heavy, but not too bad for a steel wheel. 25lbs I believe for a 17x9.
hossdoc
12-18-2007, 12:37 PM
FYI, I happen to have a 17x9 cragar D window in the shop for my current project, and unless they're made really different from the soft 8 they tip the bathroom scale at a shade under 40llbs.
Doc
68Formula
12-18-2007, 01:27 PM
My bad. Another person on a forum claimed he contacted Summit directly for those exact size and type wheels and they said the shipping weight listed was 40lbs, but actual wheel weight was 25lbs.
hossdoc
12-19-2007, 05:42 AM
That's a hell of a lot of packing then. Aero and Bassett both make black steel wheels that are around 25 lbs, but they are only available in 15 inch sizes. Wish I could find one comperable in a 17!
s4dustin
12-19-2007, 07:27 AM
Found a great deal on torq lites...18X8s....would have liked to have gone wide in the rear but dont have the cash.....
I am very excited, new brakes, Hotchkis suspension, and wheels and tires....the car will feel like it is brand new..:) i am very excited..i will post pics from start to now... :)
ProdigyCustoms
12-19-2007, 07:41 PM
The 17s will not clear the 14" anyway. You need a full 16" Inside Diameter on the inner wheel shell, and I do not know of any 17" wheel that is going to have that.
