Results 1 to 8 of 8
Thread: Filling Chevelle firewall seam
12-14-2007 #1
- Join Date
- Nov 2007
- Posts
- 266
hey on the 64 I wanna get rid of the wavy seam on the firewall and Im not sure how i want to attack this. Ive come up with two ideas, both include getting the seam sealer out. First idea is to spread some filler and feather it out. Thats the easy way out and if enough of you say no problemo on that Im gonna do that. Second way would be to cut the seam out and add in filler patches across it. I dont like this route just cause I dont like cutting original sheet metal out unless its damaged and cause you can end up with things getting misalighned, warped ect. I havent got the seam sealer out so tell you the truth i dont know if the mud route will even work( there maybe too much of a divit to do it correctly). Ideas please!!
12-15-2007 #2
- Join Date
- Nov 2007
- Posts
- 266
nothin huh? nobody has cleaned up the firewall on a chevelle?
12-15-2007 #3
- Join Date
- Sep 2007
- Location
- Elizabeth City NC
- Posts
- 233
well if you want to stay away from cutting the sheet metal you can get some fibral which is a fiberglass based filler and just use that first then go over with regular filler for the finishing. you can get a plate made to cover the whole face of the firewall then nothing really is disturbed if you use a panel bonding adhesive to attach it. Im just gonna weld mine on my camaro and weld the DSE heater box filler in and fill what ever else is needed to straighten it up same principle for the chevelle.
67 camaro
12-15-2007 #4
- Join Date
- Nov 2007
- Posts
- 266
I think that would work using a full overlay panel didnt even occur to me and just weld it on. I just dont like cutting out huge portions of metal cause I get worried that things will shift. Thanks for the idea Illl keep everyone posted when the car gets ready for that
12-15-2007 #5
