Results 1 to 4 of 4
Thread: Trans oil level ?
12-05-2007 #1
New to Pro-Touring
- Join Date
- Nov 2007
- Posts
- 4
Trans oil level ?
So what is the correct way to check transmissions oil level,engine running?I have a 4L60e,what is it's total capacity inc converter?After filling it up and a short drive it dumped a whole lot out.
Any help appreciated,Kev.
12-05-2007 #2You need to check the fluid with the transmission warm, running in park. The total capacity of a 4L60-E really depends on what style converter, pan & cooler that you are running. If it is a stock 4L60-E that is between a 1993 - 1997 it should hold 10.5 - 11 quarts (stock non 300 mm converter and a small cooler) if you have a 1997 -up (stock 300 mm converter, factory deep pan, & small cooler) is should hold 11 -11.5 quarts. I hope this helps.
12-05-2007 #3i was always told to do it in neutral.
Originally Posted by MarkB
12-05-2007 #4
New to Pro-Touring
- Join Date
- Nov 2007
- Posts
- 4
That's great,thanks,Kev.
