View Full Version : Valve Springs!!!!!!!!
69camarokid
12-02-2007, 08:58 PM
so can anyone tell me the specs on stock LT1 (95 trans am) valve springs
I was gonna order a set of Beehive 918s but every place i looked is sold out for the next two weeks. So now im looking into the 915s.
I know they can fit on a stock head with no machining needed, but i want to know if i can use my stock retainers and all that other stuff on the springs with them, or do i need to replace all that too?
i hope not cus im on a tight budget... any help would be appreciated soooo much thanks guys!https://static1.pt-content.com/images/pt/2007/12/LS1LT1flag-1.gif
heres the specs for the 915s, my new springs
Specs
OD: Top 1.055" Bottom 1.290"
ID: Top .650" Bottom .885"
Seat Pressure: 105 lbs @ 1.800''
Open Pressure: 293 lbs @ 1.200''
Coil Bind: 1.100"
Spring Rate: 313 lbs/in
Lowend
12-02-2007, 10:19 PM
You need to get matching retainers... the beehive springs use a dedicated retainer.
You might also look at the Isky 235-D with the 707 STA retainer it will fit the stock pocket and take .550 lift
