View Full Version : 10 bolt identification
JMD68RSSS
11-28-2007, 08:15 PM
Over the winter, with xmas gifts I hope to upgrade to a posi. So I have started to try and identify the rearend in my 68 camaro. It should be a 12 bolt but a previous owner swapped in a 10 bolt. From looking at pictures, I think it may be a 7.5" 10 bolt. I know the best way is to pull the cover, but they have not salted in Pittsburgh yet, so I am still driving the car. Just trying to get an idea.
What do you guys think?
11-28-2007, 09:51 PM
from that angle looks like a standard 8.2 10. Not sure if they made a 7.5 that would fit a 1st gen f-body. Maybe big gear head will chime in.
JMD68RSSS
11-29-2007, 08:16 AM
Thanks Mr Quick. I would probably keep a 8.2.
rchaskin
12-01-2007, 07:31 PM
I don't think any stock model of the 7.5" would fit in a first gen.
It is probably a 8.2" or 8.5" ten bolt.
The easiest way to id a 8.2" or 8.5" ten bolt is the pinion nut.
The 8.2" uses a 1-1/8" socket on the pinion nut.
The 8.5" uses a 1-1/4" socket on the pinion nut.
Hope this helps.
12-02-2007, 02:12 AM
easier way for 8.5 is to look at the bottom of the center housing...more material right below cover and look for the dimple in the cover.
LS6 Tommy
12-02-2007, 07:32 PM
That's definitely not an 8.5" I can't see enough to positively ID it, but it sure looks like it may be a BP 8.2".
Tommy
JMD68RSSS
12-03-2007, 09:23 AM
Thanks for the replies. I am going to try and get a wrench on the pinion nut. May get a better picture.
Is a BP 8.2 original to camaro's?
ponchopwr70
12-03-2007, 09:57 AM
Does look like a bop 8.2 rear. Does the cover have a cut on each side of the cover like a half circle?
JMD68RSSS
02-15-2008, 01:01 PM
I finally go under the car and took the cover off. It is a 7.5/7.625 10 bolt out of ???
Needs replaced.
