View Full Version : What width wheel for a 315/35/17 tire?
Samckitt
11-21-2007, 08:42 AM
Will it fit on a 10" wide wheel?
6'9"Witha69
11-21-2007, 09:24 AM
285-295 work well on 10" I would say 11" would be best unless you want it to bulge.
LS69TA
11-27-2007, 07:07 PM
10" is the minimum I'd say to run them on. I've ran them on 9.5s before, not recomended though. Ideally they should be on 17x11s.
1FstChevy
12-01-2007, 08:56 PM
Yea +1 on the recommendation of 17x11, if you take a look at tire manufacturers specs the widest tire they approve for a 10" wide wheel is a 305 which is the point I'm at, and for handling it could be argued that a 295 is better since its more square with the wheel edge or what have you... not sure of the terminoligy, but I'll likely go with a 295 next time around, I just went with the 305s since I traded for them and they were esentially free! :)
LS69TA
12-01-2007, 09:12 PM
On a 10" wheel I'd really want to run a 295 or 305 at the max.
John McIntire
12-02-2007, 05:51 AM
Mines on a 11". Its a nice fit. The sidewall is nice and square to the rim, it doesnt roll in or bulge out.
jonnyc
12-02-2007, 06:44 PM
most tire manufacturers list a 9.5 wheel as the narrowest wheel for a 315.10" will work but 11" is best.
1FstChevy
12-03-2007, 02:25 PM
Wow I wouldn't feel safe with a 315 on a 9.5" wheel, but I suppose if thats how they list it.
I know performance tire manufacturers such as Nitto tend to be a little more conservative in the range they specify, obviously since most of their customers will probably push their tires to the limit and 315 on that small of a wheel isn't a very comfortable margin.
