View Full Version : Brake advice please
Jimmy Sean
11-20-2007, 01:09 PM
I’m getting ready to run the hard brake lines for my 69 firebird. I have a hydroboost system, C5 calipers, SS flex lines for the three soft lines and a distribution/proportioning valve from a 1979 firebird with 4 wheel disk brakes. I plan on running 3/16” SS hardlines.
Is there anything I need to add or change to the system? Is there a better solution instead of the 1979 firebird block?
Apogee
11-20-2007, 04:39 PM
You should have 5 flex hoses with a 4-wheel disc car...one at each caliper and the rear axle center drop. Personally, I would run a adjustable prop valve in the rear line over the 1979 Firebird combi as you'll end up with some adjustability. Your car doesn't even remotely resemble a '79 Firebird in the brake department, so why use the combination valve from one?
dhutton
11-20-2007, 06:14 PM
With three flex lines it sounds like you are still running rear drums. If you are I think you will need a residual pressure valve, 10 psi for rear drums.
Don
Jimmy Sean
11-20-2007, 08:53 PM
Sorry brain fart, yes five ss flex lines.
If I run an adjustible proportioning valve for the rear, I will still need some type of distribution block? If so does anyone have an example of one? Or would I use the distribution block for the 1969 firebird with an adjustible proprtioning valve in the rear line?
HILROD
11-20-2007, 09:07 PM
You can run a 4 wheel drum distribution valve. As long as a 69 is like a 68 or before, only for distribution, not a prop valve or holdoff. I use the stock block to keep my brake warning light. You can also just use brass tee fittings.
zman1969
11-21-2007, 06:06 AM
there really dosent have to be 5, 3 will work - its how GM did it on the 79-81 4wd T/A's but they did allow for a little play the hard line was kinda Z'd- as there isnt much movement other than in or out as pads wear . the later cars(like my 87&99 T/A) did have 5 . I am running 5 on my 69 bird, sound cool and post up some pics!
Jimmy Sean
11-21-2007, 12:49 PM
Does there really need to be a distribution block? Could I run the front to a tee block and then to the calipers? Run the rear line through an adjustable proportioning valve then to a tee block on the axle and then to the calipers?
Can the adjustible proportioning valves be controlled by a cable from the interior? A valve like this http://store.summitracing.com/largeimage.asp?part=SUM-G3905&Prod=Summit+Brake+Proportioning+Valves&img=sum-g3905_w.jpg
by a cable like this http://store.summitracing.com/largeimage.asp?part=TIL-72-407&Prod=Tilton+Brake+Proportioning+Valves&img=til-72-407_w.jpg
