    Results 1 to 10 of 10
      Sep 2007
      Elizabeth City NC
      what size tire on a 17X7 wheel?
      Im putting 275 40 17 rears on 9.5 wheel. what tire should I get for the fronts that are 17x7 . what kind of tires are you guys using?
      67 camaro
      Oct 2006
      Pittsburgh, PA
      A 245 would fit good on an 8" rim, but...assuming that you already have the wheels, I would go with a 235 to stick with the pro-touring vibe. Anything smaller, you might end up with the Fat 'n' Skinny look of a drag car. IMO.
      Sep 2007
      Elizabeth City NC
      well nothing is in stone yet I originally was gonna do 7 on the front and 8 on the back but as I looked up here I found that a 9.5 would go on the rear I only got 1 7" front I might just sell it and get a 8 and use a 245
      67 camaro
      Jul 2007
      Belvidere, N.J.
      I am running the same size wheel and tires as you on the rear and have 17x7 with 225/45 17's on the front. I have a '68 camaro and started off with 215/50 17's up front which rubbed a little, so I switched to the 225's.
      Oct 2006
      Pittsburgh, PA
      If you look in the Wheel and Tire Database, you'll see that most of the 67's have 245's up front on 17x8" wheels w/ about 5" of backspace. One even has 275/35R18 tires up front, with 335/30R18 out back!!! (Just like Stielow's first-gens)
      Jul 2007
      Tracy, CA.
      Backspacing is key!
      Sep 2007
      Elizabeth City NC
      Quote Originally Posted by Chewy72ss
      Mine isnt Mini tubbed so a 335 wont sqeeze on the back of my car wish it would my car is still a "project" my first goal is to just get it back on the road which it hasnt seen since the 80's I just got it this year as pretty much just a rollin hull Im just keeping it basic right now.
      67 camaro
      Quote Originally Posted by Mark68
      The 215's rubbed and the 225's don't???
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by KwikGT
      The 215/50-17's have an overall diameter of 25.46 in. and the 225/45-17's are 24.97 in. They were rubbing because of the height, not width.
      Mark E.
      '68 RS/SS Camaro, 350 c.i./400 hp, Thumper Cam, Hurst shifter, Muncie M-21, Pypes H-pipe w/violator mufflers, 18" Rushforth Battery Wheels
      Thanks, that's good to know!
