    Results 1 to 3 of 3
      Jan 2007
      SOCAL
      1968 camaro aluminum door panels
      Do i have to make these or can I buy them? If so, where?
      Flo-rida
      Jegs sells a universal blank that you can cut to fit your door and just attatch them using the hardware from your original panels.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by s4dustin
      My guy made mine. This way he was able to make them fit the door better. To make life easier get a pair of OEM upper rails (from some stock door panels) and then rivet the new panel to them.
      You will also be able to ditch having to run the lower screws and just use push pins like on the rest of the panel.
      1968 Track Rat Camaro:
