    Results 1 to 4 of 4
      Rockford, IL
      Backspacing for 18x12 on mini tubbed Camaro
      What backspacing should I use on an 18x12 wheel going in a mini tubbed gen 1 Camaro running a G-bar?
      1967 Camaro Coupe
      Aug 2003
      Orlando, FL
      Depends on you rear, and what wheels you want. Some wheel have limited back space availability. Do you have your rear? Are you making the rear to fit. Do you have wheels picked out?
      to make a long story short, somewhere in the 5.5 to 6.5 backspace will work. If you need help, we have installed and sold dozens of these set ups, we have 4 of these projects in the shop today. So we can dial in all the measurments.
      four zero seven 832 1752
      Rockford, IL
      Frank, I'm buying one of your 12 bolt rear ends that is set up for the g bar.
      1967 Camaro Coupe
      Aug 2003
      Orlando, FL
      I thought so. So we can make it whatever width we need to. Do you have wheels yet? Call me and we can dial you in a lot faster then typing here.
