greygoose006
10-21-2007, 12:29 PM
well my transmission my have bit the dust.
i have an 84 caprice classic with a th-350 transmission.
it is the original transmission.
it is leaking profusely when i put it in reverse.
it has no prior issues and started suddenly.
its not coming from under the inspection cover with the flexplate and torque converter.
i dont think its coming from the gasket cause i tightened all the bolts and it is still leaking.
its not coming from the back of the transmission with the driveshaft and all that.
it is coming from the front passenger corner of the pan
it only leaks when it is in reverse that i have seen so far.
it may leak slightly in drive, but in reverse it pours out and i get the feeling that if i let it run in reverse for 30 seconds, there would be no fluid left.
PLEASE HELP
PLEASE HELP
