View Full Version : Resurfacing Wilwood Rotors
AButler
10-15-2007, 05:42 PM
How much can you remove from wilwood rotors before they reach end of life. What tolorance does the 0.810" rotor have. Or anywhere i can get the info because wilwood phones are only open till 5 pm.
Vegas69
10-15-2007, 09:49 PM
Are they turnable?
AButler
10-15-2007, 10:01 PM
Are they turnable?
Im not sure?????? I would assume so..... Thats kinda why im asking.
Vegas69
10-15-2007, 10:10 PM
I would call Wilwood first. Their is a good chance they are not if they are cross drilled and coated.
70TWO NOVA
10-16-2007, 01:15 PM
if their drilled or slotted you cant turn them. If you do the bit on the lathe will cause extremely tiny hiarline cracks in and around the holes and slots which will get a lot bigger once the rotors heat up again during braking. Not exactly safe
AButler
10-16-2007, 04:36 PM
No they are solid. Had Les Schwab turn one and it came out worse than when i took it in. Ill be purchasing new ones now.....
