View Full Version : will the stock 69 console with with a T56?
SatisTraction
10-05-2007, 01:03 PM
I am planning a ls1 t56 swap in my 69 camaro. it currently has the factory console with a horseshoe auto shifter. can it be made to work with the t56?
will69camaro
10-05-2007, 01:54 PM
I moved my console back, little tight between the seats but it's not bad. Otherwise you'd never really notice it being any different from being stock. I'll see if i can dig up some pics.
William
GeoffP
10-05-2007, 01:57 PM
I did the same, moved my console back about 6 inches (maybe a little less). It looks okay, but it does look a little odd if you know what you're looking at.
Overkill
10-08-2007, 04:54 AM
I only had to move mine back 2" to get the stick to come up in the hole correctly. I modified the stock console shift tunnel (plastic that goes from the console down to the floor around the shifter) so that it would clear the bigger boot that I put on to seal the shifter hole.
I don't have any actual pictures to show how far the tunnel was moved back, but in this picture you can see the stock forward mounting hole which I had to redrill in the little crease just in front of the automatic shifter cable grommet.
https://static1.pt-content.com/images/pt/2007/10/camaro_rebuild323-1.jpg
I really need to take some pictures of my own car when I have my camera at the car shows. I don't have any real finished pictures of it outside of a couple of exterior ones...
BonzoHansen
10-08-2007, 05:53 AM
Didn't McLeod make a relocatible shifter?
