View Full Version : Rear engined automatic
jp455
10-02-2007, 07:13 AM
Hi all...I was looking at that turbine car built by GM that Leno has. I saw that it uses a standard automatic tranny mated to a diferential to be able to use it as a rear engined transmission. Who makes that piece? Is it maybe a one off GM part? Looks pretty trick, this way cars like Ultimas could use an automatic.
Manuel Scettri
HILROD
10-02-2007, 11:55 AM
I think it's from a newer vette, minus torque tube.
Steve Chryssos
10-03-2007, 03:01 AM
That looks really slick. But excluding Jay Leno's resources, I would consider a 4T80E.
Project69
10-03-2007, 08:50 AM
Yea im pretty sure the newer vettes have transaxles.
jp455
10-04-2007, 12:23 AM
I guess it is the corvette transaxle minus the transmission. I always thought that it was a one piece casting on the vette...guess not. Thanks guys!
Manuel
Skip Fix
10-06-2007, 06:00 AM
Back in the old days an Olds Toronado or Caddy Eldo were used. In the 70s in Dallas "hot Rod Exchange" speed shop had two El Caminos with them mounted in the bed to a BBC. Easy to pull the front wheels with no motor and just a straight front axle there!
HILROD
10-06-2007, 07:11 AM
That pic is of the transaxle AND the trans.
pdq67
10-27-2007, 03:39 PM
Please look into Pontiac's OLD early '60's Tempest transaxles and see if one couldn't be reworked to do what you may want??
I do know that my Buddy tried out a used 2-dr post 336" / 326" V-8, 3-speed on the floor jobber back then and boy did it GO!!
pdq67
deuce_454
10-29-2007, 07:56 AM
corvette transaxle on ebay... you can clearely see how the diff is bolted to the t56...
http://cgi.ebay.com/ebaymotors/06-Corvette-Z06-Differential-Transaxle-3-42-Ratio_W0QQcmdZViewItemQQcategoryZ33731QQihZ010QQit emZ200166189016QQrdZ1QQsspagenameZWDVW#ebayphotoho sting
on an other note, the ultima uses a porsche or getrag transaxle that has the diff mounted between the engine and transmission... so that is a no-no on the automatic ultima....
Skip Fix
10-29-2007, 09:55 AM
The Tempests used a cable type shaft to mate the motor to the rear tranny. The autos have the torque convertor hanging out back that looks weird. Buddy busted a cable with a fairly stock 326.
Texas Hotrod
10-31-2007, 07:19 PM
I have a Turbo Htdro 425, its case and internals is designed after a TH400. It's a really strong unit and parts are available. If it could lug a big Caddy El Dorado/Toronado around, you know it has to be strong. Mine was behind a 455, others took the abuse from 500 inch Caddies.
The cool thing about this t'axle, it puts the drive shafts dead center of the engine block. It makes a really short package.
I saw an old Tomy Ivo race car. It was an Olds Toronado with a blown455/TH425 combo at each end. Dual engines, dual trannies, and smoking all 4 tires down the track (proving how much power that trans axle can take).
pdq67
11-03-2007, 03:35 PM
TV Tommy!
pdq67
Texas Hotrod
11-03-2007, 06:54 PM
You're right.
Tommy Ivo ran jet cars.
TV Tommy had all the weird, cool stuff.
The Toronado had blown 455s. He had a rail with 4 engines too, everything was Oldsmobile powered.
kmcanally
11-12-2007, 03:32 PM
Hey...I remember that speed shop.
That pic is showing basically all Vette pieces. Starting with the C5 Vette, the transmission is mated directly to the differential. In that pic, they are even using the Vette aluminum rear suspension cradle with some modifications. Here is a pic of the C5 trans and differential mated directly to the engine instead of the torque tube used in the Vette. The complete packaga is about 54" long; much too long for the Ultima. I am using it because I am building my own car and the length was something I could design around.
Ken
https://static1.pt-content.com/images/pt/2007/11/PICT0137-1.jpg
rcotteleer
07-03-2008, 09:50 AM
BB69,
What is the dimension from the bellhousing face to the axle centerline? is it the 54" or is that the overall length?
