    Results 1 to 17 of 17
      NYC
      Question for all 66-67 GM A-Body owners
      What tire n wheel combo you guys running?what sizes and backspacing and if any mods to fit big wheels under there?
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      '66 Chevelle SS:
      frt = 17x8” w/ 4.25” BS; 245/45ZR17
      rr = 17x9.5” w/ 5.625” BS; 275/40ZR17
      Baer brakes frt and rr on stock 12-bolt, rolled fender lips to clear tires.
      Bob
      Mooresville, NC
      '66 Chevelle SS (461, T-56)
      https://www.pro-touring.com/forum/vb...?do=view&g=274
      Indiana
      '66 El Camino:
      F-18x8.5 w/ 5.2 BS, 255/40-18
      R-19x10 w/ 5.5 BS, 295/35-19
      Baer GT front brakes and Baer Touring rear brakes. The rear fender lip was trimmed and rolled to ensure more than enough clearance.
      '66 Chevelle SS:
      F-18x8 w/ 4.75 BS, 255/35-18 (will eventually change it to 245/40-18)
      R-18x10 w/ 5.5 BS, 295/45-18
      Same brakes and fender lip trimming as the El.
      Pictures of both are in my PT Garage.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Loganville, GA
      Here's mine: 1967 El Camino, lowered quite a bit.
      front: 17x8, 4.75 BS 245/45/17
      rear: 17x9.5, 5.5 BS 275/40/17
      Stock 10-bolt w/Camaro LS1 rear discs
      Front SC&C stage 2 kit w/Kore3 C5 front discs
      Fits with no cutting or rubbing (so far) even with front inner fenders in. I do have 2.5 degrees of camber which helps the tire stay away from the inner fender bolts.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      NYC
      The chevelle wheel wells are the same as el camino?i`m leaning torwards an 18".
      George
      Loganville, GA
      The front is the same, not sure on the back. Just looking at Bob's 66 specs, the wheel well may be smaller on the chevelle by a little, since I didn't have to cut/roll the fender lip at all.
      1975 MGB Roadster
      2003 GSX750F Katana
      Oct 2006
      Corona, CA
      67 Chevelle: 19x8 4.75" backspace and 245/35/19. Rears are 20x10's with a 5.75" backspace, and 285/30/20's. Close to the outer fender on the rear, but they clear.
      I actually have a set like these I need to sell:
      Snohomish, Washington
      Do you guys have any rear picture shots. trying to get an idea what a 295 tire looks like.
      Matt
      NYC
      All you guys running a rear 10" rim with a 295 tire,how much clearance would you say you have on each side?
      George
      Oct 2006
      Corona, CA
      Here's a 20x10 rear with a 285. There is roughly .375" to the outer fender (the inner lip) and about .75" on the inside. The way my exhaust is run though, it comes close... like .375" close. But it clears, and I'm cutting off the exhaust tips anyway.
      Indiana
      Quote Originally Posted by staged67gspwr
      I haven't actually measured it, but eyeballing, I'd say both of my cars have at least 1/2" clearance on fender side of the tire and close to 1" on the frame side.
      If you're not in a hurry for the info, I can measure them on Monday.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      NYC
      I got about 1/4 give or take on each side with a 10" rim and a 295 tire backspacing on the rim is 5.75
      George
      Dallas TX
      any new pics of the Buick? What aspect ratio of 295 are you running. I hope to have my wheel tire combo ironed out and ordered very soon.
      NYC
      Its a 295/35/18,i`ve run into a small issue on the drivers side,it seems i have alot more clearance on the pass.side where`s on the driver side the tire is almost touchin my wheel well molding.
      George
      NYC
      heres some pix
      George
      Dallas TX
      Thanks for the pics. I think I want a little taller. I am leaning toward a 285-40-18 I got a junk 295-35 here and try to find a 285-40 to do some eyeball comparisons on
      NYC
      How much tire pressure you all running?
      George
