View Full Version : How to make these pipes?
SuperMatty
09-21-2007, 03:49 PM
Could someone recommend a method of making these pipes? They're 1-1/4" OD aluminum pipe (1-1/8" ID). I would like them to be a single piece; not cut and welded.
Matt
Samckitt
09-21-2007, 05:49 PM
What are they for?
SuperMatty
09-21-2007, 06:56 PM
Cooling system in a vehicle.
parsonsj
09-21-2007, 07:10 PM
Sure ... get a structural tubing bender, and the right mandrels. If you are making them from aluminum tube, be sure they are fully annealed. The tube lips on the end can be rolled with a tube bead roller.
jp
SuperMatty
09-21-2007, 07:57 PM
Is that something I can purchase for less than $1000? :)
09-21-2007, 09:51 PM
doubtful, I don't think the pack with sand trick will work either.
parsonsj
09-22-2007, 05:31 AM
Is that something I can purchase for less than $1000?Maybe ... but mine cost $2200 with a pair of mandrels.
SuperMatty
09-22-2007, 06:58 AM
So there's no way these pipes could be made with a rotary draw bender, like the model 3, for example?
Camaro Zach
09-22-2007, 05:31 PM
Yes you can do them with the model 3 and for less than a thousand dollars. The only problem you might run into is the bends being close together on the one piece but it shouldn't be a problem.
Where do you live? i have the jd2 model 3 and a 1 1/4" die you can use if you are close.
Bigblue73
10-05-2007, 05:50 AM
We use a conduit bender - Contact a local industrial electrical contractor.
