View Full Version : GM 600 Steering Box Kits
UNISTEER
09-19-2007, 08:02 AM
If you want to upgrade the OEM power steering box or convert to a Power Steering Box on your 1964-’95 RWD GM PASSENGER CAR but don't want to go with a rack and pinion?
No problem, we are now offering the best steering box ever offered by GM- Delphi. The GM “600 series” Power Steering Boxes were originally designed for NASCAR.
The GM 600 Box is slightly lighter than other power steering boxes and is available in several different ratios for optimal steering performance depending on the vehicle; 12:1, 14:1, and 16:1 ratios are available for this steering box. These Power Steering Boxes will accommodate heavier rides with ease as well. We offer this box alone or with the necessary rag-joint (coupler) and adapter fittings that enable you to use your existing sttering hoses.
https://static1.pt-content.com/images/pt/2007/09/8040050-1.gif
We also offer the correct GM Type II/TC power steering pump that is internally adjusted for the proper fluid flow and pressure to give you the very best “Box & Pump” steering available.
https://static1.pt-content.com/images/pt/2007/09/8060300-1.jpg
We are currently offering a 10% discount & FREE SHIPPPING (to lower 48 states only) for a period of 60 days on anything we sell.
So if you are interested in improving the steering of your ride take a look at our website and use the discount code: PT-10
70TWO NOVA
09-19-2007, 08:49 AM
Thanks, as you know im in the market for a steering upgrade for my Nova right now, But will this box bolt right up to the frame of my 72 Nova and what sort of bracketry/belt changes are needed to get the pump to bolt up to my small block?? If it can work I will probably go with you guys. That dicount is a really good incentive.
NvrDun71
09-19-2007, 09:08 AM
I'm curious as well, would like to do the whole swap on my 71' Nova:
GM 600 steering box kit, w/ necessary pump and hoses
UNISTEER
09-19-2007, 09:37 AM
Guys,
If you already have a factory style Saginaw power steering pump (pictured below) and hose all you have to do is buy one of the kits pictured with the rag-joint and adapters for your hoses.
https://static1.pt-content.com/images/pt/2007/09/8060290-1.jpghttps://static1.pt-content.com/images/pt/2007/09/8060280-1.jpg
If you currently do not have any pump at all we can set you up with a stock style Saginaw in black or chrome (pictured above) or one of our GEN II set up's. The GEN II is a compact pump that mounts differently than the stock style Saginaw pumps.
The GEN II pump can be configured in a ton of different ways according to your needs:
Cast or Polished
With Clip-On Reservoir
With Remote-Mounted Reservoir
Standard Fittings
AN Fittings
Single Groove V-Belt Pulley
Dual Groove V-Belt Pulley
Serpentine Pulley
70TWO NOVA
09-19-2007, 11:25 AM
Im looking to do the 600 series gearbox, the gen2 pump (cast) with the clip on reservoir, single groove pulley, and standard lines. Now what kind of fittings are needed with the 600 gearbox (AN??) because you said i would need adapters for stock lines and pump. If I went with the gen2 pump and 600 box would both have AN fitting or how does that work?? And what would all this cost?
Also why is the gen2 pump better and if I wanted to upgrade later down the road could I??
UNISTEER
09-19-2007, 12:30 PM
Brian,
If you already have a factory PS pump all you need to buy is a 600 series kit with the rag-joint and adapters (pictured above).
There is no advantage to a GEN II pump concerning performance when using a 600 series box or any factory gear box for that matter.
70TWO NOVA
09-19-2007, 01:25 PM
I think you just got yourself a sale! Could you please give me a price quote with the 10% discount on your 600 box, rag joint and the necessary line adapters to fit a 1972 Nova. Thank you so much, you have been a great help!
whytry
09-19-2007, 02:35 PM
Do you have anything for us manual guys? :lurk:
BBPanel
09-19-2007, 09:29 PM
...No problem, we are now offering the best steering box ever offered by GM- Delphi. The GM “600 series” Power Steering Boxes were originally designed for NASCAR... Physically how does this compare to the 66 Nova stock steering box - as in would it provide any additional header clearance? Thanks. -Bob
Little Bill
09-23-2007, 02:43 AM
You mention 12:1, 14:1 and 16:1 was never sure but is it the larger the number as in 16:1 is faster or quicker turning than 12:1 or is it the other way around. Sorry for the dumb question was never sure. Each time I have asked a friend they aren't sure or give me the balank stare.:pat:
70TWO NOVA
09-23-2007, 10:07 AM
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off"></TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>opposite, 12:1 is quicker.
6'9"Witha69
09-24-2007, 10:27 AM
It is the ratio of turns of the box input to turns of the pitman arm or output shaft. Just think that if your wheels turn 45* in either direction, for 90* total left to right (1/4 circle), and the steering wheel turns 3 times lock to lock. this is a 12:1 ratio. More steering wheel turns for the same output is a slower (numerically higher) box. i.e. 4 turns lock to lock would be 16:1, 3.5 would be 14:1.
Little Bill
09-24-2007, 10:34 AM
thanks for the education. I appreciate it .
TonyHuntimer
09-24-2007, 11:35 PM
I can't wait until I can afford to get rid of my Steeroids rack and pinion in my Camaro. The bump-steer is unbearable.
I'm considering just installing a crappy old original steering box to get rid of it.
Tony Huntimer
http://www.goodies-speedshop.com/
UNISTEER
09-25-2007, 10:23 AM
Brad,
We offer a Manual rack for your car, but unfortunately nothing in a performance-oriented manual gear box.
UNISTEER
09-25-2007, 10:25 AM
Tony,
As they say..... "once you go rack you never go back":geek: Unfortunately for you you haven't really had the pleasure of experiencing a R&P set up w/o the bumpsteer issues.
Get in touch with me when you are ready to swap the Steeroids out.
Tony Huntimer
CarlC
09-25-2007, 10:45 AM
A few questions if you don't mind.
What is the flowrate of the "Low Flow" pumps? I've had good luck with 1450psi @ 3gpm.
Also, many of us use the LS1 F-body accessory drive. The pump in the first post will not work due to the vertical mounting bolt arrangement. Do you offer another pump/reservoir combination that will work and offer -6 out and return?
Thanks.
TonyHuntimer
09-26-2007, 10:38 PM
Unisteer,
I've been unhappy with the Steeroids rack from the first day I actually drove the car with it installed because of the bump-steer and the amount that it hangs down.
As you know...the Steeroids rack hangs down much lower than yours (yours is almost nothing)... I drive my car everyday so I periodically smack the Steeroids rack bracket on uneven road surfaces. Well, I hit a mammoth pothole this morning and whacked it really bad. My alignment is way out now. I can tell that I'm having severe toe-out issues. :pat: I'm debating having it re-aligned or tweaking the bracket back into place and welding it in so it won't move again.
I wish your kit had been on the market when I bought mine. I know that I'd be much happier.
I'm publically appologizing to everyone who bought my Pro-Touring book and bought a Steeroids rack for your Camaro because I included pictures of installing it. I'm sorry! If you have not purchased a steering rack for your Camaro yet and you are planning on upgrading, buy a Unisteer rack and pinion. I have not driven a Unisteer equipped Camaro, but it's got to be better than mine.
...steering impaired,
Tony Huntimer
Disclaimer...Maybe the Steeroids kits for other models of cars are better than the one for the first gen Camaro, but I don't know.
staged67gspwr
09-27-2007, 03:35 AM
Whats the price on these boxes?
UNISTEER
09-28-2007, 08:30 AM
Thanks.
Our hi-flow pumps are 3 GPM and 1200-1300 psi
Our remote pumps have -6 AN on pressure side & -10 AN on the return. The housing is the same as the OEM C4 & up Vette pumps.
UNISTEER
09-28-2007, 08:37 AM
George,
The kits retail for $449.00 + shipping which is really a great price, but for a limited time you can get 10% off & FREE shipping (48 states) on anything we carry. That makes it $405.10 shipped to you anywhere in the lower 48 states.
Just be sure to use the discount code PT-10 when you checkout.
BAP
10-02-2007, 04:30 AM
Thanks for the info I appreciate it.
ahowudoin
10-02-2007, 08:07 PM
Is this the same as a DSE pump? or what is the difference and what is the warranty.
Thanks, Ken
UNISTEER
10-11-2007, 09:28 AM
Thanks, Ken
Hey Ken, both gears are sourced from GM-Delphi and we offer a one year warranty on them from the date of purchase.
jtmiller92
10-15-2007, 12:20 AM
So will this work on a 92 Camaro, I would want something in the 12:1 ratio with increased "feel".
UNISTEER
10-15-2007, 05:31 AM
The 600 series boxes fit 1964-’95 RWD GM passenger cars, so your in luck. Take a look at the link below for the 12.7:1 box:
http://www.unisteer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=UNISTEER&Product_Code=8040050&Category_Code=
70TWO NOVA
10-15-2007, 07:53 AM
I already bought mine and just finished installing it. Ill post pics soon, cant tell you how well it works yet cause i still need to put the motor back in the car. The quality looks awsome though.
UNISTEER
10-15-2007, 08:25 AM
Sounds good Brian! Send us your comment and a pic of the car, not sure if you put it on the Nova or Camaro and we'll put it on our website!
70TWO NOVA
10-15-2007, 08:54 AM
I actually put it on the Nova. Ill be sure to send you a comment and a Pic, thanks again.
West Texas Z
10-18-2007, 12:33 PM
Just one quick qustion, would this work on my 1974 Camaro?
I lost the powersteering in my car, and the pump seems to pump the fluid just fine. I'm wondering if the belt is slipping or is my grear box blown?
dipren443
10-24-2007, 09:15 AM
I just installed the 670 steering box from SC & C into my 73 Z/28. I didn't see this offer prior to ordering. The box will bolt right in without an issue. I haven't had an opportunity to drive the car yet, but I should have driving impressions soon. You will need the hybrid rag joint as well.
West Texas Z
10-24-2007, 11:49 AM
Thanks, will you let me know how it works after driving it for a while. I'm interested to know. Thanks again. :idea:
BulldawgMusclecars
11-28-2007, 11:06 PM
Will this work in a C3 Vette application? It has PS now, but its the crappy assist style with a control valve, like older PS equipped Chevys. I have considered rach and pinion, but have herd bad things about Steeroids and the VB&P "Rack Attack" is so new I haven't heard anything definite on it.
79T/Aman
01-10-2008, 07:47 PM
how was it "designed" for "NASCAR" I crewed with arca teams in the past and we all used 800 boxes!?
SLAMDIMPALA
01-13-2008, 04:42 PM
Do you have a kit for a 63 impala? I have power assist and its shot. I have alot of play so i am looking for a new steering box and what ever else is involved.
dipren443
01-13-2008, 05:30 PM
The internals are very similar. There is just a slight difference in size. The 670 box is a little smaller and lighter. Other than that, they are built on the same internal architecture.
dipren443
01-13-2008, 05:33 PM
Saw this post bumped back up and I wanted to let you know that I never did get any driving time on the new box before the car had to be put away for winter. My detailed driving impressions will not come until spring... Gosh darned Northeastern winters... :screwy:
65Camino
02-23-2008, 06:32 PM
What options (sizes) are there for the road feel from the "t Bar" with this box?
velozo
03-09-2008, 12:24 PM
Does anyone have a pic of the box and pump installed in their car?
ls1 nova
03-09-2008, 08:36 PM
Unisteer,
I have a 1970 nova with the camaro short steering arms and the long pitman and idler arm. My steering is 2 1/4 turns lock to lock. Not sure what box I have(came with the car) What ratio do you recomend?
tomspo04
03-21-2008, 06:51 PM
Unisteer, I need a price on a 600 12:1 box with matching type II pump and hose set. Will my 70 Camaro pitman arm still work?
BSER
04-17-2008, 01:45 PM
I have a factory power steering unit in my El Camino and the steering is very slow and sloppy. Would your unit cure this problem and if so what is your price.
The power steering has developed a leak and i will be replacing it ASAP.
Donovan
04-18-2008, 12:57 PM
I read through this and have some questions and requests... :)
What is the point of doing this swap? Say if you already have a good factory quick turn box?
A little lighter? How much lighter exactly?
Is there an actual performance improvement that can be quantified next to a similar factory unit?
I would love to see a side by side comparison of the boxes to see where it may help with size or shape. Like for header clearance.
Thanks!
badazz81z28
03-02-2013, 09:24 AM
UNISTEER still around?? Interested in a box and its not on their site...
dipren443
03-03-2013, 11:32 AM
Rob,
Go here. http://lee-powersteering.com/
Nick
badazz81z28
05-28-2013, 05:17 PM
I couldn't get a hold of him...bought a 600 series from Rick's Camaro
LeighP
06-02-2013, 03:26 AM
I have a 670 12.7:1 box in my 71 Firebird....man, they should have built them like that in the first place...great feel and steering.
badazz81z28
06-03-2013, 07:04 PM
I got my box today. Looks great, but the instructions say NO synthetic PS fluid????
harry k
05-17-2017, 07:07 AM
So what brand/vendor is available now a days for these boxes reasonably priced?
i see DSE offers them at $750,but way out of my budget,any info thanks in advance.
drb930
03-15-2021, 06:24 PM
Has anyone figured out what GM/Delphi Car/Truck these "cores" came off of?
Seems it is impossible to find 1 of these for under a grand :-(
79T/Aman
08-22-2021, 12:34 PM
Pro-TouringF-Body.com
Depending on what you want they rage from $799-2300
