View Full Version : Satin Black Pics
skeeters65
09-17-2007, 04:50 PM
I am looking for some pictures of cars that are Satin Black..
Paint codes would also be very help full..
Looking for somthing similar to this..
https://static1.pt-content.com/images/pt/2007/09/69flat-1.jpg
danbob67
09-17-2007, 06:42 PM
you might check out duponts "hot hues" they got one called hot rod black I believe. they also have some clears that cure to a semi gloss finish that you could put over any black base coat.
69Bbird
09-17-2007, 07:02 PM
Mine is painted with DP90 primer
Discoquik
09-21-2007, 06:04 AM
Mine are both Dupont Hot Rod Black Single stage done after House of Kolor Base/Clear and rub out..... lots of masking! Easy to spray....and YOU CAN WAX IT!!!:naughty:
StRacerDuke
09-22-2007, 06:58 AM
Waxing it is the key. Primer as you probably already know isn't the best idea, even if it's PPG's epoxy DP90.
Check with your local paint shop. Many times they can add flattener agents to the paint to get you the finish you are looking for. Just make sure you lay down your paint right the first time because you can't exactly wet sand and buff it out.
Brian-Blade
09-25-2007, 07:43 AM
I used :
Pre-flattened PPG clear .Part# DCU2060 - FLEXED N FLAT CLEAR
over DP-90lf
http://new.photos.yahoo.com/brian120444060/album/576460762316143708/photo/294928804429847917/196
SicMonte
09-25-2007, 10:37 AM
i used U-POL spray paint on mine..i know i know...but it cost me $45 for the entire paint job and it looks good enough for me. I'll put up some pics later.
there is also a line of colors from kustomshop.com called "Hot Rod Flatz"...good stuff there!
Project69
09-25-2007, 12:36 PM
Well i know where im buying my paint from lol
Thanks SicMonte.
Taylor1969
09-25-2007, 02:07 PM
Not the whole car, but my underhood is all flat black
I used a flattening agent with PPG Black paint
SicMonte
09-25-2007, 09:39 PM
here are some pics of the spraypaint...i wasnt kidding!!!
scogin918
09-27-2007, 10:29 AM
Just looked this up on Dupont's website and it states that polishing is not recommended as it will affect the gloss level of the paint.
http://pc.dupont.com/HotHues/deployedContent/en/us/html/images/prod_HHM-6400pg_ER3838.pdf
Tom Welch
09-27-2007, 06:26 PM
StRacerDuke, can you enlighten us as to the waxing? Does this keep the car looking cleaner or blacker?
Discoquik
10-08-2007, 08:02 AM
Point taken. However it's been three years of constant sun exposure and with Zoop's wax I have seen zero change between the exposed (waxed) and unexposed (unwaxed) areas. I sprayed the Volvo this spring and to hold the dragsters nose up to the Volvo they are identical. Zero change in sheen or "color". The original body on the dragster I shot with DP90, two coats of Omni Clear to bury a metalflake stripe 70 T/A style stripe, wetsanded and recleared with flattening agent added to the clear with a ratio of 5 ounces Fl agent to 10 ounces of clear. Much experimenting made it the perfect sheen. HOWEVER, the flattening agent DID make the black and 'flake look a lil milky. That's why I only used the "agent" in the final topcoat. It wasn't awful, looked great just not as natural as a single stage urethane. Dupont is the best for durability and "hold out". Jesse James had Dupont develop this product and with the time that he puts into a bike I would have to believe the standards of the top coat would have to match the quality of the fab work.:hail:
This pic was taken last month after three years of racing.
Discoquik
10-08-2007, 08:06 AM
Here is the Volvo freshly sprayed.....
Stupidnewbie
10-11-2007, 02:35 PM
These aren't my cars, so I can't comment on paint codes. I just love satin black cars and my Firebird will be painted this way. I know BASF is making a new flattened clear called "Carizzma Flat." Check it out here: http://www.carizzmacolors.com/news.php
Benoit23
10-11-2007, 05:53 PM
I love your Drag cars!!!!:seizure:
What is that last boxy car??
:cool:
Discoquik
09-30-2008, 02:31 PM
:cool:
A Volvo of course 9.85 at 135 with a flat top 440 Chrysler through Ultra Flow Mufflers 6000 RPM.
hotrdblder
09-30-2008, 03:51 PM
duponts single stage hot rod black works nice but is pricey at 125 a quart set up, S.E.M has a hot rod black to that is as nice at duponts at half price.
the ultimate is to use a reg black base, and a satin or flat clear, i use standox and they have a killer satin and flat clear, when done in a booth you have little dust and the longevity of a clear.
comp-spec
09-30-2008, 04:29 PM
dp 90
https://static1.pt-content.com/images/noimg.gifhttps://static1.pt-content.com/images/noimg.gif
Discoquik
10-01-2008, 07:34 AM
DP looks great for about three months after that it's a chalkboard
GBodyGMachine
10-01-2008, 07:49 AM
I like the idea od matte black. Im just concerned about cleaning it.
Any Tips?
Im thinking of doing the hood, roof, and trunk lid flat, and the rest of the car maroon.
CRead01
10-01-2008, 01:19 PM
I like the Dupont Hot Rod Black also. The racing stripe on my car is done with this and I love it. just the right satin.
TonyL
10-01-2008, 01:27 PM
My "paint" (DP90) is almost a year old and just as black as they day i sprayed it.
I do park it inside on the days I don't drive it though.
scogin918
10-01-2008, 05:37 PM
here's mine. Just painted it last night. Sherwin Williams Dimensions 5.0 Acrylic Enamel w/ flattening agent. This is the plan for the outside of the car as well for right now.
https://static1.pt-content.com/images/pt/2008/10/DSC01458-1.jpg
skeeters65
10-03-2008, 01:36 PM
That SW stuff looks sweet..
sacarguy
11-05-2008, 04:06 PM
WHAT COLOR is that last car thats liek a smoke titanium with flat clear.
