View Full Version : Wires to doors
EFI69Cam
09-06-2007, 08:37 AM
Is there a way to cleanly run wires into the doors on a 69 Camaro without removing the fenders?
Also are there some OEM looking boots available anywhere?
Project69
09-06-2007, 10:50 AM
Yea your gonna need an right angle drill. http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?N=10000003+90401+1688&catalogId=10053&locStoreNum=8125&marketID=401&productId=100342144&storeId=10051
As for the boots, id check ebay for ones that you like.
MickMc
09-06-2007, 03:04 PM
the wiring boots I have used in the past are from the 80's chevy truck.
They are easy to find in any U-Pull It yard and work like a charm.
If you need a picture, drop me an email and I will grap an extra one and take a picture
[email protected]
Mick
ProdigyCustoms
09-06-2007, 03:56 PM
You can drill the door side hole from inside the door, just make sure the drill does not grab and twist denting the door. The door frame side is straight forward. The hot set up is braided tubes from Electric Life.
EFI69Cam
09-07-2007, 09:42 AM
Thanks for the ideas!
I think I will do some basic "will it fit" tests with the drill in the door.
twisting can be avoided by sneeking up on the final size?
CamaroAJ
09-07-2007, 11:56 AM
2002 camaro, you'll need a 2 3/4 hole saw and a 1 3/4 hole saw. go to the junk yard and get them.
https://static1.pt-content.com/images/pt/2007/09/camaro1211006-1.jpg
ProTouring442
09-08-2007, 01:41 AM
A little smaller and very nice looking, not to mention easy to get, are the boots from a '90s GM W body. That's the Pontiac Bonneville, Olds 88, etc.
Shiny Side Up!
Bill
