View Full Version : Front sway bar for 69 Camaro
skeeters65
09-04-2007, 08:07 AM
I was wondering what you guys are runniing for swaybars on your first gens??
It is a basiclly stock front end with DSE 2" drop springs and their shocks..
The car will has an LS1 if that matters..
jknight16
09-04-2007, 08:22 AM
Myself and most guys around here run the Hotchkis 1 1/8" hollow sway bar, part #2207-F.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HSS%2D2207F&N=700+400083+115&autoview=sku
JK
skeeters65
09-04-2007, 09:29 AM
How hard is it to install this unit??
Do you need to modify anything or is it direct bolt on??
jknight16
09-04-2007, 09:38 AM
It was a direct bolt on for me. maybe took a half hour. It's a little bit easier to install if you have the rest of the suspension apart doing a rebuild like I did but that's not necessary. You can get it in there according to hotchkis' instructions with a little turning/twisting, etc in about an hour, two at most. You might scratch it up a little bit in the process, but if you're worried about it you could wrap it in painters tape.
skeeters65
09-04-2007, 10:19 AM
jknight,
Thanks for all the great info!! I will be ordering it today or tomorrow..
Do you run a rear sway bar?? If so any info on that??
The car has DSE MiniTubs, will that effect anything??
jknight16
09-04-2007, 10:24 AM
No problem skeeter, glad to help.
I don't currently run a rear sway bar, since i really don't think its necessary for how I intend to use the car (street w/ occasional autocross). I'm by no means an authority on the merits of using a rear sway bar though. But I'm sure some other guys can chime in here or you would probably be well served to do a search for rear sway bar. I know it has been discussed in great detail in the past. I don't think you'll have any problems with the mini-tub, though, don't think it makes a difference.
skeeters65
09-04-2007, 10:49 AM
cool thanks again..
67 455 Bird ragtop
10-02-2007, 06:54 AM
Any real difference between a SOLID 1" and the 1 1/8" hollow bars?? I currently have a solid 1" used on the 69 T/As. Car mainly street/strip car. Global West tubular upper/lower arms and QA1 coilovers. Any real reason to switch to the hollow version ??
6'9"Witha69
10-02-2007, 08:38 AM
Any real difference between a SOLID 1" and the 1 1/8" hollow bars?? I currently have a solid 1" used on the 69 T/As. Car mainly street/strip car. Global West tubular upper/lower arms and QA1 coilovers. Any real reason to switch to the hollow version ??Weight. Other than that they offer similar torsion.
The car has DSE MiniTubs, will that effect anything??With DSE tubs I assume you will have much more tire in the rear than up front. That will cause understeer. You can add a rear bar to promote oversteer and try to balance the car.
wendell
10-02-2007, 09:21 AM
Like 69 said, the 1 1/8" hollow is exactly the same stiffness as the 1" solid. the weight difference is about 6#. You'll never notice 6#.
