    Results 1 to 18 of 18
      Eastland, Tx
      c6 wheels on 68 camaro?
      Do you guys know if c6 wheels will fit on a 68 camaro? Or what your comments would be on that. Post pics if anyone has done it.
      Bubba Cox
      Odessa, Tx
      1968 Camaro
      oregon
      Can't help with the fitment question...but I have a set if your interested ;)
      Feb 2007
      if you use space/adapters they will work.you need to be ruffly around
      5" of backspace.give or take 1/2"
      Flo-rida
      What i know will fit is if the rim is 9.5 wide with a 54mm offset, will work with a 2'' spacer.
      Here is my car with c5 z06 wheels, 17 x 9.5 fronts and 18 x 9.5 rear. what sizes are you looking at getting? Or are you looking at getting ones to fit?
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Flo-rida
      Something tells me that theres alot more to the suspension then meets the eye???
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      ...and a good eye you have. Its a competetion spin drift car we assembled. Features 1 x 2" Tecx one rims with 35/45/2 's Pilot sports. Suspension is Ballzout ball bearing track II with ARP 1/4" hardware.
      We are still working out the acceleration part of the car...without kicking the skates off LOL
      Flo-rida
      Nice, im pretty sure id kill to have my suspenion set-up like that hehe.
      Whats under the hood...or what will be doesnt look like an engine is in that yet...
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      LOL, we could hook you up.
      No the car was finished and sold last year. LS1 T56 and C4 IRS...just figured out I didn't update the page.
      Eastland, Tx
      Found a set around here for $1,300. wheels and tires.
      Bubba Cox
      Odessa, Tx
      1968 Camaro
      May 2002
      Northern California
      Good stuff, does it come with spacers?
      Flo-rida
      If there the OEM size then i think they might be to big for stock fenders, adn what not. Cause im pushing 285 on a 9.5 rim in the back with no mods to the fender lips and stock tubs and there really close to both.
      For the front im using a 255 tire on the same width rim and i had to take the fender wells out just to turn. So Id find some 18 x 8.5 on the safe side or go with a 9.5 rim if your not planning on cutting the car to make them fit.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Sep 2004
      San Diego, California
      I have the C5 replicas that are 17 x 9.5 all around. If I recall correctly I'm running the 2" studded ADAPTERS, not just spacers.
      B.t.w. Vince, do you think the adapters a good, bad, ok idea? I got them from VBP and they said guys race with them. This would be for normal street driving and occasional autox?
      I don't mean to whore the thread, but I think it could be relevant to the op's question.
      Here's a pic of my Project POS.
      Cheers
      John
      May 2002
      Northern California
      Adapter spacers are fine. A lot of guys race with them. Just be sure to use a hub centric design (VB 's are) and torque them to proper spec. I like to check mine every oil change. Looks good.
      These rims will require work to fit them. Dont get me wrong, they will fit.
      Eastland, Tx
      It's just the wheels and tires. No spacers. I think they are factory Vette wheels.
      I wouldn't mind removing the inner wheel wells. But I don't want to cut the rear.
      Bubba Cox
      Odessa, Tx
      1968 Camaro
      Oregon
      Factory C6's come with runflats and tire pressure sensors, so make sure you're not paying for those. I picked up a set of 5-spokes off of a 2005 for $275 in decent shape for my Nova project. I'm making wheel adapters front and rear and putting them where I need them. Needless to say, everything is tight with a 19x10 rear wheel with 285/35R19...I plan to cut to fit and possibly lose the front inner fenderwells.
      May 2002
      Northern California
      APO, that size fronts are you running? Im working in a section width of 11 1/8" tire and can offer some suggestions to keep those wheel wells.
      Oregon
      Quote Originally Posted by MrQuick
      Noooooo...those are the rears. Just running the 18 x 8.5 front C6 wheels with 245/40R18 rubber, same as the Vettes. Sorry for the confusion on my previous post.
      Not to hijack, but I am interested how you're getting that wide of a CS to fit and others may as well.
