View Full Version : Moser 12 bolt fit
69HuggrrrPT
08-02-2007, 07:00 PM
Does anyone know if these are exactly the same size as stock front to back with a 1350 yoke?
In other words will the driveshaft have to be shortened at all if I'm running a 12 bolt already?
08-02-2007, 07:39 PM
...there is usually enough play in the trans yolk shaft to take up the slack. but my swag is no, it should go right in.
ProdigyCustoms
08-03-2007, 03:35 AM
Sold tons of them, they are direct bolt in replacemnts, unless you specify otherwise.
69HuggrrrPT
08-03-2007, 05:07 AM
Frank, will Moser weld the perches on to give the pinion a specified up or down angle?
Will I still be able to use my Baer brakes?
