    Results 1 to 20 of 27
      Wichita, KS
      Anyone running BFG KDW2 Tires? Got Pics?
      Is anyone running BFG KDW2s on their ride? If so, post some pics of your wheels/tires showing the tread.
      I have saw pics on the BFG website, but have not seen any pics of the actual tire mounted on a wheel.
      Attached is the pic from BFGs website...
      SouthTX
      I just happened to take a couple of shots of my new tires for my 69 Camaro, here they are.
      Arlington,TX
      On 18" Simmons wheels.
      BRIAN WEST
      Sep 2004
      No offense but that Tire pattern looks like it belongs on off road 4 x 4 truck. I like the original style better.
      Frank what size are these rims onthe pictures below with the 295/35/18 Not the mustang please let me know Thanks, BP
      Quote Originally Posted by 4MuscleMachines
      SouthTX
      18x8 and 255/40/18s Front
      18x10 and 295/35/18s Rear
      Going on 69 Camaro with no mini tub.
      Mountain View, CA
      Has anyone used the old and new tread pattern? Any difference in performance?
      They are going to continue the old pattern right?
      True T.
      My blog
      Nov 2004
      Colorado
      Quote Originally Posted by Damn True
      Dscontinued according to discount tire.
      Nov 2004
      Colorado
      What front and rear BS are you using? Rolled lips in back?
      Thanks.
      Wichita, KS
      You are going to run a 11.9" tire on a 69 Camaro w/ no mini tub? You going to roll the lips? I am not sure on the 69s, but on my 67 I have 11" clearance between fender well and lip. What do the 69s have?
      Maybe you are not going to tuck it under the lip? I am interested to know...
      I was going to put a 275/40/18 on my 18x9.5" wheel just because it was a 10.9" tire. I am still going to probably roll the lip just because I am cutting it close.
      SouthTX
      Quote Originally Posted by EFI69Cam
      Thanks.
      It wouldn't be accurate if I told you since the track width has been changed from original due to the suspension changes and brakes changes. If you still want to know, just PM me and I will measure them since they are still off the car.
      SouthTX
      Quote Originally Posted by bigboi
      The lips have been agressively rolled in the back. I have been running it like this for a while with only VERY minor rubbing. It hardly ever rubs at all when driven hard. Here is one pic of the stance with the same tire brand and sizes on the rear but worn out. The fronts pictured are 245's but 255's should work once I get the alignment changed.
      Some other guys have done it as well. It has been discussed in the past.
      Wichita, KS
      Whew... That back tire looked STUFFED in there. Bad ass my friend - baaad ass!
      If you get a chance to take a closer picture of the rear tire tucked in there I would love to see it!
      Mountain View, CA
      Tire Rack has them in mass quantities. I hope that continues to be the case.
      True T.
      My blog
      Mar 2002
      North California
      Also Jegs has them..I just got a full set front/rear from them.
      There probably not the best tires out there,but I love the way
      they look and they last awhile..lol,well at least the fronts do.
      Here is jegs link..
      http://www.jegs.com/webapp/wcs/store...59969_-1_36688
      -Jim
      Wichita, KS
      Out of the BFG Tires I have seen I think I like the BFG KDs - Not KDW or KDW2s.
      The tread design looks pretty cool... Well at least I think so. To each their own though...
      Los Angeles
      Costco sells BFG as well.
      California Bay Area
      How do you guys like these tires? Im either going to get them or the nitto 555.
      65 Impala
      01 Z06
      Mountain View, CA
      The 555 has a softer compound and a stiffer sidewall. So the BFG's will last a little longer and ride a bit quieter. The 555 is better suited to use for auto-x and open track events. But the BFG is certainly capable of doing both of those things, just a degree or two less effectively.
      True T.
      My blog
      Illinois
      heres the bird with 255/45/18's
      A link to some pictures of my Firebirds and other toys
      http://community.webshots.com/user/ponchoman69
