View Full Version : Tie Rod question
Gaslight
07-24-2007, 09:33 AM
I have a 73 Nova that I have added the ATS AFX spindles to and am using the 69 Camaro Z28 short tie rod arms on. The rims I have are lightly contacting the rim inner surface. I ordered up the Baer trackers but given the size of the they actually make the problem worse. Before I look into a little more narrow of a front wheel I wanted to see if there are any other tie rod or tie rod arm options out there that might sort me out.
Jake
eville
07-24-2007, 09:47 AM
I think someone else here used a washer to shim the steering arm away from the rim.
Gaslight
07-24-2007, 09:54 AM
I saw that and it is one option I am looking at. Although I would rather have the arm bolted directly to the spindle. At least that would be my number 1 choice. But spacing it away is also on the table.
Jake
07-24-2007, 07:25 PM
Jake, what size rim are you running? Spacing the rim outward an option?
