    Results 1 to 6 of 6
      San Antonio, Tx
      18" back spacing on a 67 camaro
      i'm getting ready to order my wheels for the camaro but changed plans from 17" inch front rim to 18's, i want to run a 255 at least, i looked in the wheel data base and there is two cars with a 18x8 and a 18x8.5 and both have a 245 on them, i'm not worried about the fender wells as i will be making new ones so if anybody has some back spacing numbers that would help alot :icon996:
      Instagram: CamaroAJ
      Jan 2003
      Arizona
      With 18's you have some options which means you need to address some questions:
      1) Is your car painted? In other words are you still in a position to roll your wheelwell lips?
      2) Have you relocated your shocks inboard? In the stock location they should fit inside 18" diameter wheels. But I moved my shocks inboard back when I had a set of wacky Wheel Vintiques 17" rally wheels, so I can't tell you for sure--but stock shocks will almost definitely fit inside 18's.
      Based on those variables (and a few other measurements) you may be able to fit up to a 10" wheel (actually 11" wide overall). I have 18"x10" wheels with 5.25" (maybe it's 5.5"?) backspacing mounted on 285/35 Nitto tires. So you should be able to fit an 18"x8" or 18"x9" wheel no problem. I would consider an 18"x9" with 5" backspacing on a 275 tire. Based on my measurements, you will have plenty of tire to lip clearance.
      I'd hate to see you run an 8 with a 245 and then wish you had more wheel and tire. So take some measurements and remember that 18's are more forgiving than 17's or smaller.
      ________________
      Steve Chryssos
      El Dorado Hills, CA
      Just by chance what wheel are you ordering? I am thinking of increasing from a 8 to a 9.5...... Budnik Fat Lip Fontana
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      San Antonio, Tx
      steve are we talking about front shocks? i may have not made it very clear that thats what i was talking about now if you are talking about the front then this is very good news for me. no the car is not painted yet, and also i have the full DSE front kit (tube upper and lower arms and coil-over kit) so if that will make a differance, the rear is mini-tubed. i am getting Budnik Famosa dish 18x12 5.5 bs and what ever 18" front wheel we decide on here.
      Instagram: CamaroAJ
      Jan 2003
      Arizona
      Whoa. No, I thought you were talking about the rear. Front is a different story. In the front, an 8"/4.5" to 4.75" wheel is tight and 245 is as wide as I'd go when running a stock clip (no C4 or C5 parts).
      Sorry, I thought you were talkin about the rear. I was refering to the lower shock mounts in the rear interfering with wheels when pushing the limits of width and backspace.
      ________________
      Steve Chryssos
      Apr 2002
      North Central Texas
      My 67 is mini tubbed and I have 18x12 w/6.5" BS (335/30-18). My rearend measures 57" from wheel mounting pad to wheel mounting pad. On the front I have 17x8 w/5.25" BS (255/40-17). Now my car does not have the front clip on it yet, so I may have some massaging to do......
      Shannon
