Results 1 to 7 of 7
07-21-2007 #1
Starting The Transformation
- Join Date
- Feb 2007
- Posts
- 327
I need some advice on what to do about frame rot.
I have a couple of small rot holes in the front third of my frame and I always find a lot of large loose rust flakes on the inside of my frame. I know some of you might say "get another frame" but where I live if I am lucky enough to be able to find a car with a frame close enough to be able to use it will either be just as bad or not much better. I'm looking for advice on good ways to deal with this constant rust problem I have? Thanks
09-23-2007 #2
- Join Date
- Jul 2007
- Location
- Woburn MA (work)
- Posts
- 190
If you are gping to go the way of least expensive,clean it up as best you can (and that is REALLY time consuming) and then throw something on it to protect it- Id also suggest not keeping it out side if you do now- the condensation just makes it worse.
Originally Posted by aggressive male
Lenny Schaeffer
Woburn MA
09-23-2007 #3
- Join Date
- Aug 2001
- Posts
- 924
