View Full Version : Where to put proportioning valve?
ITLBTU
07-01-2007, 07:35 AM
Do I put it in front of the factory metering block or after? My '69 Camaro was drum/drum, now it is disc/disc? I'm thinking that it should be after, but if you know for sure please chime in.
Hammered
07-01-2007, 02:33 PM
If you put it before the factory block, it will set off the brake imbalance switch on the block.
gmachinz
07-01-2007, 04:07 PM
I wouldn't even use an in-line type anyway. I like to install 3rd gen. Camaro combo/prop valves for 2 or 4 wheel disc brake conversions. I use them for all of our Camaro and any A-body disc brake conversions. The weight bias is a good match for them. I bend all my own lines for them and this way I can route them however I want.
Samckitt
07-01-2007, 06:45 PM
Gmachinz,
So you say instead of getting an adjustable inline prop valve, to use the factory 3rd gen camaro part? Got a part number?
thanks
07-01-2007, 10:59 PM
...last time i checked they are no longer available over the counter.
i haven't had luck with the disc/drum unit.
Hammered
07-01-2007, 11:10 PM
Does the 3rd gen use a bubble or inverted flare?
k9ulan
07-02-2007, 04:11 AM
combination valve?
07-02-2007, 07:56 AM
combo valve uses the standard flare, same as your older car but the fittings are odd ball. If you go to the wreckers to get it make sure you cut the lines after the fittings a take with it.
