    Results 1 to 6 of 6
      Snohomish, Washington
      Regal wheel questions
      hey guys. i was just looking at some cheap wheels for now and i was wondering what the lug nut pattern on 85 regals is. i found some replica bmw wheels with a 5x120mm. is the 120 mm the same as the 4.75? is the regal a 4.75 too? would they happen to fit?
      here is a link to the wheels, they are the first 2.
      http://www.lakeshorewheelandtire.com...bmw-3-18.shtml
      Matt
      Dec 2009
      Comox, B.C. Canada
      4.75 is the same as 120.7mm dont worry.
      Nov 2009
      Colorado
      What is the offset for the rims? The bolt pattern is the same but would the offset or the back spacing be different?
      dayton, oh
      factory offset for g-bodies was 0mm, or about 4.25" backspacing. you may need a 1" adapter for those wheels, but they should bolt up.
      dave.t
      74 Javelin AMX - stocker
      Nov 2009
      Fort Walton Beach, FL
      Just to let you know, the bolt pattern is not the same between BMW and GM. BMW is 5X4.72 and GM is 5X4.75. Sounds minimal but you may need hubcentric rings to make sure it centers. Just do a search on the site for BMW wheels and you'll get a lot of info that helps with the decision
      Kevin
      73 Nova
      355/TH350 (soon to be T56)
      07 Trailblazer SS AWD
      Stock (for now)
      Frederick, CO
      Actually the BS on G Body's is 3.75" / -6mm on the 15" wheels.
      Larry.
