    Results 1 to 10 of 10
      Apr 2007
      Odenton MD
      wheel lock removal
      Hey guy I got my car home a few days a go.. Now I want to take the wheels off but the wheels have locks on them... And I don't have the key them.....How do I go about removing them....
      St.Anne Il
      do you own a air impact ? i have seen my buddy pound large socket over them and zip them off might have to get 4 new lugs though..but it does work seen it with own eyes..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Aug 2005
      Patterson, NY
      Most shops have the sockets for removing those locks, or any rounded off lug nut. They are kind of like easy-outs for nuts.
      Apr 2007
      Odenton MD
      thanks guys I don't have a impact.... I saw a tool at pep boys but was not sure if it would work or not it looks kinda cheap
      Southern Indiana
      http://www.steckmfg.com/
      Try these guys the tools they have are tough and will do the trick for those and stripped lugs too. worth every penny spent if you dont like any local shops.
      Lee
      Nov 2004
      If you can remove the center cap and put visegrips securely on it and see if it'll move, as long as the the lugs aren't over torqued it should come off. A cold chisel and a hammer starting at 10 o'clock will also work taking your time.
      Gerald
      May 2002
      Northern California
      your better off bringing it to a shop and have them impact off like Darrin suggested. if you wack em off wrong, say bye bye to them rims.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jun 2006
      TX
      tighten the **** out of the other lugs so that the lock will be a lil looser. then use a chisel and try to turn it. worked for me.
      May 2007
      Houston, Tx
      i used a vice grip and manged to get mine off...you should give it a shot
      Colin Russ
      Southern Indiana
      Another trick is get a buddy to weld a nut on the top of the ock and then remove it with regular socket.
      I used card board over the lock when we do this and just wet it down before welding, also jack car up so slag and sparks wont melt tire.
