View Full Version : 76 trans am rear rim size
nitrovette
05-25-2007, 07:12 AM
Im most likely inheriting a 76 trans am in the next week.I have 17x9.5 with 4 1/8 bs boyd coddington starburst rims on my 73 vette,can i put them on the trans am on the rear ,my fronts will fit 17x8 4 inch bs.Im looking to get new rims for the vette anyway.
WhiteG240
05-25-2007, 07:40 AM
You should be able to fit them. Most guys with 2nd Gen Firebirds/TA's will run a 17x9.5 with a 5.5 backspacing. They generally run 17x8 with either a 4 or 4.5 backspacing on the fronts.
Where is Absecon NJ? I'm in Jersey and have never heard of that town before...
nitrovette
05-25-2007, 08:24 AM
yeah i figured theyll probably not have enough bs,maybe stick out an inch or less ,im 5 minutes out of atlantic city.
O'Neall
05-27-2007, 07:56 AM
The fronts should be fine with 4"... but yeah, the rears will probably stick out a bit past the wheel well lip... I've seen 9.5" wide rims run 5" backspace though and it looked good... so it may not be too bad with 4.5".
Post some pics when you get the car.
nitrovette
05-28-2007, 02:46 AM
thanks i guess ill try it and see if not ill look for rims.
