View Full Version : GBODY GMACHINE Update with Pics
GBodyGMachine
05-24-2007, 02:01 PM
Hey guys. Things have been moving rather slow. I keep running out of money so it is hard to make any real progress. I did get the rear end in though. It took a little time but it fits well and the coil overs look great too. Next I am going to put the front clip back on, thats free. Then I want to get the front brakes complete and hopefully set the car on the ground for the first time on 18's.
Jeff
https://static1.pt-content.com/images/pt/2007/05/Wheels023-1.jpg
https://static1.pt-content.com/images/pt/2007/05/Wheels024-1.jpg
https://static1.pt-content.com/images/pt/2007/05/Wheels025-1.jpg
https://static1.pt-content.com/images/pt/2007/05/Wheels026-1.jpg
https://static1.pt-content.com/images/pt/2007/05/Wheels029-1.jpg
Samckitt
05-24-2007, 02:07 PM
Looks good! I like the coil overs, now it has got me thinking.....
Tony_SS
05-24-2007, 02:50 PM
The center bar looks like it could hit the top of the differential on a rough bump...
GBodyGMachine
05-24-2007, 04:14 PM
thanks for the comments.
Tony, It looks close but there is about 6 inch's of clearance.
Jeff
GBodyGMachine
05-25-2007, 02:26 AM
I received an I M yesterday asking what the setup was.
I am running double adjustable upper control arms from Ebay as well as double adjustable lower control arms from Ebay. I cut out the orig spring pockets off the frame and put in my own crossmember and bracing. I made the coilover brackets for the axle out of 1/4" steel and welded them on. The Coilovers are from Strange with 200lb Hypercoil Springs. I really like them. The brakes are from SSBC and are ment for a 12 bolt from an A-body, but I made them fit.
Any other ?'s please ask.
Jeff
racereno
05-25-2007, 06:20 PM
Lookin' good! Really nice work Jeff. I like the idea of cutting off the spring pockets.
796spdbu
05-25-2007, 10:20 PM
How about a 3/4 view of the rear wheel, so we can gauge the tire width compared to the quarter panel??What size wheels and tires are they.I love the fab work, looks killer.Keep the pics and info flowing!!
GBodyGMachine
05-26-2007, 05:31 AM
The Wheel is not bolted to the axle at the moment, it will sit about 1/2" further in. The size is 295/35/18.
I am going to remove the chrome trim and roll the quarter a little bit so I can get it to tuck just a little bit. I should have that done within the next couple weeks.
Jeff
https://static1.pt-content.com/images/pt/2007/05/Wheels027-1.jpg
trapin
05-26-2007, 07:26 AM
I'll bet there's a lot of people watching this build. I think the G-Body is probably the most intriguing of all the late model builds. When all the Malibu's are swallowed up...these will probably be next. Nice progress on the car, and keep us posted.
796spdbu
05-26-2007, 08:04 PM
NICE...i really dig it.just the right amount of tire for me.I agree that when all the malibus are gone these will take there place.I have kept an eye on your build and it looks killer.:headbang:
GBodyGMachine
05-27-2007, 05:43 AM
I dont know why the Malibu hit as hard as it did. I think it has a bit more muscular look to it, but the Regal and GN is the only G-body I have a "thing" for. The tail lights do it for me.
Jeff
formula98
05-27-2007, 08:14 AM
Making great progress. Keep it coming.
twfurst
06-11-2007, 09:21 AM
After seeing how awesome the coilovers look, I'm seriously considering something similar on my 87 SS. If I may ask, which Strange coilovers are those? I'm not totally sure on what the proper lengths for extended and compressed should be.
SicMonte
06-11-2007, 09:32 AM
Looks really good jeff!!! The rear suspension came out very nice. What motor are you going to run in this puppy??
GBodyGMachine
06-11-2007, 04:15 PM
This year I am running a SBC 383 Stroker with a TH-350. Next year Im going to build a sick N/A 408 LS
muthstryker
06-11-2007, 04:47 PM
hey jeff do you have anymore pictures of your car, im going to pick up my 85 regal soon. trying to get an idea for parts and taht.
GBodyGMachine
06-11-2007, 05:41 PM
I will be posting some this weekend.
Jeff
deuce_454
06-12-2007, 03:18 AM
whar wheels are those.. FLīs or somthing else all together.. knowing you its somthing id better look into my self...
GBodyGMachine
06-12-2007, 03:29 PM
LOL. They are BSA's. Ebay Special.
JEff
deuce_454
06-13-2007, 12:09 PM
size??? and et? i take it they are BMW wheels?? 18x8 and 18X10??? backspacing etc??
GBodyGMachine
06-13-2007, 03:31 PM
18x9 and 18x10. They are for a BMW. I had spacers made and I dont have the BS calculations in front of me right now. not sure what ET is but let me know.
Jeff
deuce_454
06-14-2007, 09:23 AM
ET is a sort of backspacing measurement that always comes on european and jap wheels, its is the backspacing in milimeters measured from the centerline and out..
im asking about size because ive been considdering buying one if those ebay sets od staggered 18 or 19 X 8.5 and 9.5 that every ebay wheelshop sells,
muthstryker
06-14-2007, 02:21 PM
what size spaces did you have made? im going to get a set of bmw wheels for a regal and im going to need some spacers. i know that if i put my 12 bolt on the car, its an inch longer on each side, would that be ok with out any spacers or not? just seeing what you think about it.
GBodyGMachine
06-14-2007, 05:40 PM
Sorry it took so long to respond. They are 8" Springs. The shortest coilovers Strange makes. You could go taller if you wanted but this was good for my application. When you build it from scratch, it could be different then mine.
Jeff
GBodyGMachine
06-14-2007, 05:43 PM
I will figure that out tomorrow. But I have a frame notch so it may be different from what you need. I think a 9.5 will fit out back without a notch, 8.5 up front is still wide.
Jeff
GBodyGMachine
06-14-2007, 05:44 PM
The spacer up front is 1.760" and out back 1.000". I will calculate the total BS when I find the specs for the wheels.
JEff
73supreme455
12-25-2008, 09:07 PM
Nice regal
GBodyGMachine
12-26-2008, 10:14 AM
Thankyou.
riceca
12-27-2008, 06:17 PM
Would love to see some more pics of the car.
lata
CHRIS
GBodyGMachine
12-29-2008, 06:30 AM
lata
CHRIS
https://static1.pt-content.com/images/pt/2008/12/New006-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Wheels0251-1.jpg
https://static1.pt-content.com/images/pt/2008/12/IMG_4043-1.jpg
GBodyGMachine
12-29-2008, 06:32 AM
https://static1.pt-content.com/images/pt/2008/12/00011-1.jpg
https://static1.pt-content.com/images/pt/2008/05/IMG_2808-1.jpg
https://static1.pt-content.com/images/pt/2008/12/IMG_9292-1.jpg
mr.regal
12-29-2008, 07:51 AM
nice to see another guy with a regal!! im defiantly keeping my eye on this build, it is very similar to mine! keep up the good work!
GBodyGMachine
12-29-2008, 02:11 PM
Link to a thread with pics of your build?
Jeff
riceca
12-29-2008, 06:01 PM
Where are those pics taken... In Mustang hell?? haha
lata
CHRIS
