toofun
05-23-2007, 05:37 AM
I buying a TPI 350 motor. I have an aftermarket computer and the harness as well. Everything at least for what I was told was that this is set up for a plug and play application, 350 HP. So my question is... How do I route the fuel lines? I plan on using an external fuel pump mounted close to the tank. I know many of you prefer an inside tank pump but for ease of installation I am thinking the outside pump would be better.
What kind of lines to I need to run? Also, Does everything need to be hard lined or can I use clamps and hoses? If so where would I run them? Can I use a DOUBLE lined fuel sending unit in the tank and if so how would I run the return line? I guess I am trying to do everything with the fuel system correct since I want to make sure I have a leak free, safe system for this TPI motor. Also where would I run the fuel filter and should I run a regulator?? Sorry for all the questions but I am a EFI newbie.
Thanks In Advance.
Mark
TOOFUN
Thanks In Advance.
Mark
TOOFUN
