View Full Version : 3rd brakelight on 67 camaro
chavez o
05-17-2007, 09:16 AM
I added a third brake light to my 67 camaro, in the spoiler. Since the brake and the signal use the same wire, I get a flashing 3rd brake when I put the signal on. Anyone ever install something similiar? If so how did you split the circuit to keep the 3rd brake light on when the turn signal is flashing? I was thinking of running a seperate wire to the brake light switch, but I don't know.
smittys69
05-17-2007, 01:04 PM
Your brake signal wire should be separate from your turn signal wire. I can't remember the colors off the top of my head but once you get that straightened out, you'll be able to wire it up correctly.
MonzaRacer
05-17-2007, 08:33 PM
on old cars without divorced turn signals you will need a new wire rom switch under dash to light.
LarryB
05-29-2007, 03:31 PM
The wire, is one of the wire on the brake light switch above the brake pedal. You have to use a test light to get the right one.
Larry
05-29-2007, 04:49 PM
I agree, come right off of the brake switch.
Steve1968LS2
05-29-2007, 04:58 PM
I wish someone would make a damn spoiler with the light already built in.
What's involved in putting the light into the spoiler?
Overkill
05-30-2007, 11:33 AM
Not a lot...
I just used a dremel to carve out an opening for a C5 light in the spoiler of mine. Then just drilled a hole in the deck lid for the brake wire to run through. I did "dimple" the deck lid a little to get enough clearance for the light, but I think it would clear if I would have mounted the light up higher in the spoiler.
Before Paint:
https://static1.pt-content.com/images/pt/2005/01/camaro_rebuild101-1.jpg
After Paint:
https://static1.pt-content.com/images/pt/2007/05/camaro_rebuild681-1.jpg
68Formula
05-30-2007, 12:13 PM
Leave it flashing should keep people more alert as you make turns too!
Steve1968LS2
05-30-2007, 02:30 PM
Not a lot...
Before Paint:
After Paint:
What's the part number of that light assembly? This is something on my list for Penny Version 1.2
Any pics of the inside of the spoiler showing the light installed?
Overkill
05-31-2007, 09:21 AM
No pics of the inside. Didn't think to take any... Might be something that I'll have to do.
I saved the label from the GM package that it came in. I'll have to dig through my boxes of stuff to see if I can find it. I thought I had it in an Excel spreadsheet of my parts, but guess I hadn't thrown it in there yet. I tried finding it online, but I'm not sure if it is a GM number or not, but http://www.corvetteamerica.com/cf/displaylearnmore.cfm?learnmoreid=371&idlist=32,1098,2208,3944,4398,2209,64,30,2107,51,5 0,33,65,107,5334,2115,164,165,166,2521,204,3487,25 8,3394,2884,3078,2050,5334,3304,841,164,165,2371,1 66,2521,3487,4465,5510,262,5058,258,3078,286,4046, 2050,320,321,204,2949,262,2609,5058,5059,1532,258, 3347,3394,2884,3078,286,1434,4046,2050,2072,1424,2 464,320,1150,331,2464,2142,301,320,319,318,3178,31 6,331,302,321,258,1371,370,369,1218,1324,371,2634, 1670&searchdest=%2Fcf%2Flearnmorelist%2Ecfm%3Fsubcatego ryid%3DX860&subcategoryid=X860 has it on there as 38502. I don't remember the cost that I paid, but I think it was around $100 since I got it at employee cost through my roommate at the time. I can't remember if it came with the wiring pigtail or if I had to buy that also.
smittys69
05-31-2007, 07:54 PM
Here's a pic of mine and it is a C5 light as well that I just bought off of Ebay for less than $100. I didn't have to dimple the lid to make it work. We actually glassed in a couple of blocks to screw the assembly to - sorry, don't have pics though
68Formula
05-31-2007, 09:16 PM
I saw pictures of two 67/68 1st Gens with 3rd Gen Tran Am spoilers. I thought if they could do it with a regular one, how about one of the later ones with the brake light?
Bought one off of eBay and had a scrap trunk lid to mock it up on. Because of the sharp downturn just at the rear of the body it has to sit forward a little, so the contours match up from the side view, but it still looks like it belongs there. The width is perfect for those years too.
Sorry, never took pics and the parts are in storage. It was just a mockup at that stage, but when I'm ready to repaint I'll be putting it on.
slenning
06-04-2007, 10:29 AM
Here's a couple pix of mine with a 2001 Cavalier light. It's very small in depth, so no dimpling of the deck lid was needed. It fit flush with the inside of the spoiler so I just ran the screws into a couple of clips to mount it.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us)
06-04-2007, 02:38 PM
that looks real nice. I may put mine in the panel between the glass and trunk.
6'9"Witha69
06-04-2007, 04:20 PM
I noticed that 2000+Monte Carlos have a similar light to the Vette one shown above (at least on the SS model with a spoiler I saw).
Overkill
06-05-2007, 04:43 AM
Yeah, I think the light is common across different models, but didn't get a list from my old roommate on which models they listed it for.
HILROD
06-05-2007, 05:07 AM
The Monte carlo light is bigger, it mounts inside the decklid. I've got a Cavalier light for mine.
Steve1968LS2
06-05-2007, 06:00 AM
[/URL]
[URL="http://imageshack.us"] (http://imageshack.us)
Do you happen to have the part number for this light?
Looks great!
Overkill
06-18-2007, 05:07 AM
I dug through some of my boxes this weekend, but didn't find the part number for the Corvette light.
Project69
06-18-2007, 11:24 PM
I liek them all, but went with the cut a section out of the middle deal with my spoiler lol.
Chevy
06-30-2007, 12:41 AM
I agree with you Mike--but unfortunately the local police disagree. I was forced to re-wire mine during safety check. As has been said, the only way to do it is to run another wire from the switch under the brake pedal. Very simple to do, but, as you know, if you want to run it with the other wires going to the rear lighting harness, you'll need to take a chunk of your interior apart to run it.
Steve1968LS2
09-13-2007, 07:20 AM
Anyone have the part number for the Cavalier light????
I can't find it anywhere... :(
Taylor1969
09-13-2007, 10:06 AM
I have been looking for a setup as well. Here is what I have found
http://www.spoilerlights.com/servlet/Categories?category=Chevrolet:Cavalier
It looks a little long - 15.5 inches, but it could be a misprint.
HILROD
09-13-2007, 02:25 PM
The light part number is, 22611505-LAMP HIGH MOUNT, the plug is,12085481-CONNECTOR REPLACEMENT PACK, the longer version of the plug, with the longer wires is,12148769-harness assembly. The light fits up to 03-4-5 Cavalier, unsure on what year they start.
slenning
09-14-2007, 04:31 AM
Sorry Steve, I totally forgot this thread. :hammer:I just put a call in to my bodyman to verify the part number on the brake light. I will post as soon as I find out.
72Z/28
09-14-2007, 06:24 AM
The Vettes 3rd brakelight looks better than the Cavalier 3rd brakelight. Just MO..
Taylor1969
09-14-2007, 06:45 AM
I think I prefer the rectangular Cavalier light. It seems to flow better with the taillights on the first gen
Taylor1969
Thats not bad... About $75 shipped from GMpartsdirect.com
6'9"Witha69
09-14-2007, 09:23 AM
I also noticed the 3rd light on the Dodge Magnum today (too much time sitting in traffic everyday) might work as it has a little more of an LED look to it to match the taillights better.
09-15-2007, 12:04 AM
Magnum CHMSL pn is 4806100AC
Also a nice clear lense red LED one is from a high line Mitsubishi Galant pn MR971523 price is $77.68 Its Modular so you can mount it pretty much anywhere.
esenior
09-17-2007, 09:24 AM
I also wanted to add a 3roiler (69 Camaro). I ended up purchasing an LED light from Watson Streetworks a couple of years ago (car still under construction). They have several choices, including billet frames:
http://www.watsons-streetworks.com/leds_plus.html
The Light I picked (Part #L58SMB) is designed to mount from behind and to be sanded smooth with the body and eventually clear-coated over. Since I am painting the car red, it is my hope that the light (when not lit) will blend in with the body.
Here's a picture after the initial install...
https://static1.pt-content.com/images/pt/2007/09/69CAMAROPT_041219_14MJPG-1.jpg
Here's a shot after being sanded smooth with the body...
https://static1.pt-content.com/images/pt/2007/09/69CAMAROPT_061028_12MJPG-1.jpg
---Eric
HILROD
09-26-2007, 05:21 PM
This is the Cavalier light installed.https://static1.pt-content.com/images/noimg.gif This is with it lit up.https://static1.pt-content.com/images/noimg.gif It matches the tail lamps great, it'd look even better with L.E.D.s
Mr. B
10-09-2007, 08:19 AM
I like the Cavalier light. That's what I'm going with on my 67.
MCMLXIX
10-13-2007, 07:18 PM
I have a 67 Chevelle and a spolier wasn't and option. I ended up using a LED 3rd brake light from a Tahoe (1998 and older) and mounted it on my rear deck lid inside the back window... It matches my LED tail lights and you can see it for a good distance. Right now I have it just hooked up to one barke light and it flashes when I signal left.... :crying: My idea was to hook it up to BOTH brake lights BUT put a diode in line with each positive wire from left and right light... This would keep it from feeding back to the brake light and basically makes an "OR" logic circuit... but this will still let it blink if you have your signal on and you don't have your foot on the brake... The wiring is just a theory... Havent had a chance to try it yet.... Radio Shack has a pack of diodes for like $1.94 . . .
They came out bad .. the camera take crap pictures at night ...
One close...
https://static1.pt-content.com/images/pt/2007/10/th_DSC04009-1.jpg (http://i70.photobucket.com/albums/i98/mcmlxix/Chevelle/DSC04009.jpg)
and one from across the street ....
https://static1.pt-content.com/images/pt/2007/10/th_DSC04010-1.jpg (http://i70.photobucket.com/albums/i98/mcmlxix/Chevelle/DSC04010.jpg)
nekkidhillbilly
12-18-2007, 08:18 PM
id like to see one from a caddillac on one the big one
