    Results 1 to 17 of 17
      Monterey Peninsula
      Is 9.5" as wide as you can run on a '69?
      Rear wheel of course.Will an 11" wheel require a mini-tub?
      Inquiring minds want to know....
      www.buickfunnycar.com
      Nov 2004
      In my case, yes, a 9.5" wide wheel with 5.5 BS and a 275 section tire is the max. My driver side rear tire just kisses inner fender when the passenger front is jacked up. The passenger side tire section just knicks the unrolled fender lip - enough to leave a faint line on the tire. Also, my car has been lowered and the rear fender height is 24.5" from the ground. My car has a slight rearend shift to the passenger side, which I'm assuming most do.
      You might get a 10" wheel in there if you're willing to roll the fender lip.
      Monterey Peninsula
      Quote Originally Posted by Neil B
      Thanks...that is strange though that your car rubs,how stiff is your suspension?Reason why I ask is because my car sits 23.5" from the center of the rear wheelwell to the ground (gotta love being able to walk out to the garage huh? ) and I'm currently running a 285/40 on a 17x9.5 w/5.5" b/s and I have no rubbing issues now.The only place it rubbed was when the body flexed going up driveways or culverts and only on the inner pass rear tire against the exhaust tube...I had them cut off and dump at the mufflers in front of the axle so no more issues there.My fenders have been rolled good.
      I'm thinking of going to a 5.25" or maybe (maybe) a 5" b/s to pull the wheel out a hair.
      Anybody run this combo?
      Here's my car:
      Monterey Peninsula
      here's a better angle of the rear clearance...
      Nov 2004
      John,
      I've got Hotchkis 2407C's up front and stock leaf springs with 1" blocks in the rear. You've got more room than I do because your fender lips are rolled. I love your car!
      Here's mine:
      Old School:
      New School:
      Rockford, MN
      Neil, are your wheels 17" or 18"?
      1969 Firebird, Black, Parchment Arizen interior, Poncho 383 (4" crank), Kauffman heads, TKO600, Moser 12 bolt, Wilwoods, DSE, Speed Tech, Koni, Hotchkis, GW, 18" TTI's, VA Gen IV, etc.
      Nov 2004
      Quote Originally Posted by Josh69
      17x8 4.5 BS front and 17x9.5 5.5 BS rear
      Feb 2003
      Houston, TX
      I've had 10" wheels on both '69s and now on the '67. All with 5.5" bs
      The rim width isn't as critical as the tire brand and tire width. Some brands run wider than they are rated, some run narrow or have rounded shoulders.
      Narrow tires = Toyo Proxes, Nitto
      Wide tires = Goodyear, BFG
      I can run 275s no problem, and run 285s with fender lip rolling. All on lowered vehicles.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Nov 2004
      All cars are different, but in my case, I've got 11 7/8" to play with between the inner fender and the fender lip. A 275 tire on a 9.5 rim gives me a section width of 11". Assuming a perfectly centered axle (which mine isn't) and perfect wheel offset (to center the tire in the wheel well) that leaves 7/16" clearance on each side of the tire. Pretty tight.
      Monterey Peninsula
      I've seen your car Neil,can't make up my mind which wheels I like best on it though.White would look good with these:
      All my buddies are minilight crazy here:
      Cincinnati, ohio
      [quote=musclecarjohn]I've seen your car Neil,can't make up my mind which wheels I like best on it though.White would look good with these:
      [/ What wheel is on the Camaro on the top? What are the specs? They look really nice!!! Thanks
      SouthTX
      I agree with NineBall, in the end it is really the tire brand that mostly determines the widest that can fit on a non-minitubbed car. Here is mine with a BFG 295/35/18 on a 10" wheel (tire is 11.9" wide).
      In the 3rd and 4th pics the car is dropped more (and dirtier at the shop). I cannot recall the backspacing, but the backspacing had to be tweaked really well to make them fit and the lips were rolled.
      So Cal
      musclecarjohn....what wheels are those on your yellow/black 69? can you post up a side shots?
      Houston, Tx
      [quote=4MuscleMachines]I agree with NineBall, in the end it is really the tire brand that mostly determines the widest that can fit on a non-minitubbed car. Here is mine with a BFG 295/35/18 on a 10" wheel (tire is 11.9" wide).
      Is that a stock 69 blue color? It looks amazing
      Feb 2003
      Houston, TX
      Appears to be LeMans blue. Factory color for 69
      www.DV8Motoring.com
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by 72NovaSS
      Vintage Wheel Works "V 40"'s
      So Cal
