    Results 1 to 4 of 4
      Phoenix, Arizona
      Reccommended Suspension components
      Hello,
      I am currently doing a 1966 Oldsmobile 2 door Cutlass Coupe into a 442 clone that has some G-machine mods. Any anyone reccomend suspension/steering components that will help plant this car to the road WITHOUT breaking the bank? Any information would be most helpful. Thanks.
      jtenney75
      May 2002
      Northern California
      Hi JT, nice throw a wrench in there would you? "without breaking the bank"?? I'd say invest in shocks, springs and sway bars...maybe a tall spindle tube UCA job? still an A body. good luck with that
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Phoenix, Arizona
      Vince,
      Any known kits that would creat the look of a G-Machine for an A-body Olds? I'm new to the g-machine/pro-touring concept so any ideas would help. Thanks for the reply.
      jtenney75
      Jul 2002
      Mesquite, TX
      Any of the Chevelle kits for equivalent years should work for your Olds. If you're looking for one-stop shopping, check out the setups from Global West (www.globalwest.net) or Hotchkis (www.hotchkis.com). I believe that Edelbrock (www.edelbrock.com) has sets for A-bodies as well, and Hotrods To Hell (www.hotrodstohell.net) has both their truckarm setup for the rear and some front end updates for A-bodies.
      If you'd prefer to mix-and-match, check out what some of the other A-body folks around here have done/are doing - you're sure to get some great ideas that way.
      Before you start throwing money at the suspension, figure out what you're really wanting to do with the car though - a decent percentage of people would be just fine with a new set of bushings, ball joints, and tie rods - not to mention a set of vaguely sticky tires.
