    Results 1 to 3 of 3
      wheels drilled for screws and slicks
      ive got a set of wheels on a 67 camaro that i bought to restore eventually. i want to steal the wheels to mount track tires for my running 67 camaro. the only problem is that they are drilled and screwed for the slicks. is this a problem. will i be able to mount a pair of mickey t street slicks on there, or will the screw holes cause poblems? (leaks, etc) if i do mount the street slicks should i run with the screws or leave them off? thanks
      Feb 2003
      Houston, TX
      Holes shouldn't be a problem since they are above the seal area. I've ran quite a few non-screwed tires on screwed wheels. Street slicks? I'm guessing you mean drag radials? If so, no screws needed unless you are running 9s at the track.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      yea, drag radials. i was drawing a blank on what they were called this morning when posting. thanks for the help.
