Results 1 to 8 of 8
Thread: Wiring woes
12-17-2004 #1
- Join Date
- Sep 2004
- Location
- Portland, OR
- Posts
- 15
Wiring woes
I am currently rewirng my 68 Mustang. I am using an EZ wire harness. My problem at the moment is that when I put on my left turn signal my flashers come on. When my flashers come on, all of the lights on the car except for headlights flash. i.e. license plate light and my dash lights. Anyone have any ideas? I was hoping to finish up the wiring this weekend.
Thank you.
12-17-2004 #2Do you have all the grounds installed? Sounds like you wired the flasher into the whole loop...
12-18-2004 #3
- Join Date
- Sep 2004
- Location
- Portland, OR
- Posts
- 15
I believe that I have everything grounded but will double check. I will check the wiring for the flashers.
12-19-2004 #468 Stang,
I had the same problem with I used the EZ kit for one of my chevelles! It took me forever to figure it out. It turns out that the kit doesn't have the emergency flasher relay needed. You'll have to run the right and left turn signals from separate power sources and bypass your flashers. I just ended up not using emergency flashers on the car. I was really disappointed by the kit. It took me forever to wire the damn thing! Maybe you can call EZ and see if they make a relay now. I used the kit about 5 years ago, so they might have fixed the problem by now.
Hope this helps~Ryan
12-19-2004 #5ez wiring
I used the 18 circuit setup on my 69 amx last spring and I didnt have any problems with the flashers or turn signals. Only suggestion I might offer is to go back and read the booklet real careful and recheck your wiring. I did have a few other things that didnt work right the first time and in going over everything again I found a few wires that I got hooked up wrong
Mike
12-19-2004 #6
