View Full Version : Paint for master cylinder??
Jim H
04-19-2007, 09:33 AM
Is there any paint out there that will stand up to brake fluid? I want to paint the exterior of my master cylinder and want something that will stay on.
silver69camaro
04-19-2007, 10:00 AM
There isn't much, but I use Polane from Sherwin Williams for anything that might come in contact with brake fluid (firewalls, etc). Only comes in black and stinks like heck. I've had a few spills that sat for quite a while and didn't even cause a blemish.
You have to buy it at Sherwin Williams Industrial Coatings, BTW, not a standard SW store.
ProTouring442
04-19-2007, 01:31 PM
I have had good luck with POR15, sliver. My dad, on the other hand, hasn't, but I swear his master cylinder is pourus.
Shiny Side Up!
Bill
MuscleRodz
04-20-2007, 07:40 AM
Use a synthetic brake fluid and it is less like paint stripper. Then most paints should stand up to it.
Mike
Mark Hamburg
04-25-2007, 12:41 AM
What are the drawbacks of synthetic brake fluid?
MuscleRodz
04-25-2007, 08:04 AM
None that I know of except maybe cost. Synthetic brake fluid has a higher boiling point than DOT 3 as well
mike
BRIAN
04-25-2007, 08:31 AM
Use a spray bottle full of soapy water. Spray down the surrounding areas and be very carefull. You could also disassemble and powdercoat if your guy is good.
I think Valvoline??makes a synthetic blend that is not as caustic.
Nine Ball
04-25-2007, 05:16 PM
I'd avoid Valvoline synthetic. Several of us tried it in our C6 Corvette clutch hyd systems and they boil faster than regular DOT non-synthetic fluids, causing the clutch pedal to stick to the floor. The Prestone synthetic works much better.
Jim H
04-26-2007, 07:25 PM
What would one use to flush the dot 3 out?
paul67
04-26-2007, 11:57 PM
What about brake caliper paint
